Old June 11th, 2019, 12:54 PM
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
Default Is the 230 Derived from the Continental Flathead?
Is the 230 OHC just a Continental flathead six with a different cylinder head? Someone on another forum I'm on posted this idea up as a justification for condemning it, and I'd like to be armed with some facts before I tell 'em they're full of it.
My hunch is no, but that's all it is: a hunch.
Old June 11th, 2019, 01:59 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
I think no. No common parts, supposedly fresh sheet design for the Tornado and the overhead cam makes just about everything except 6 cylinders in a line different about the engines.
Old June 11th, 2019, 02:00 PM
Barrman's Avatar
Chief 9-flats
I think the main bearing count is different as well. That is not an easy thing to change.
Old June 11th, 2019, 03:19 PM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
No.
The Hurricane engine that came before the Tornado was based on continental design.
However, the Tornado block, heads, etc. were new designs.
Here is a good article about the tornado's development.
https://news.pickuptrucks.com/2012/0...aight-six.html
Old June 15th, 2019, 05:16 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Absolutely concur...the 230 was a new from scratch engine.
The only thing these 2 share is a common bolt pattern at the bellhousing due to them needing to bolt to the same transmissions...the 226 flathead WILL bolt to a tans that a 230 bolts to directly. That is the only engine swap one can do in an M715 without adapters or changes at the bellhousing...though I dont know if motor mounts work...and if they do, I would bet the civilian 230 and the 226 would be the 2 that match up...the military 230 has different mounts and would bet those arent close.
  #6
Old June 17th, 2019, 07:09 AM
Corporal
Thanks everyone. I have a problem with people confidently (even arrogantly) dispensing misinformation & I like to remedy that when I can by providing facts.
  #7
Old June 17th, 2019, 06:12 PM
brute4c's Avatar
Grand Poobah
A great policy...having facts on file will serve you well in this world!
  #8
Old June 19th, 2019, 01:52 PM
Corporal
Quote:
That's what I was taught & it's worked well so far.
1998 - 2019
Copyright 1998-2019
