Results 1 to 10 of 14
Thread: small block chevy mounts
    Default small block chevy mounts
    what is everybody doing for mounts for a small block chevy?
    Pics would be great!
    thanks
    Springdale, Arkansas
    I made my own with 1/4" plate and the original engine mounts combo. They are called Spicer Plates for the guy who invented them. They're easy to make and work very well.
    Here's a shot of them installed:
    Hope this helps.
    Did the same thing FNG did-one thing you might want to consider is what you are going to run for exhaust. I ended up with a smaller triangle shape because I was running shorty headers and with a larger plate they were touching. Just FYI before you have to start grinding on nice painted pieces because you didnt preplan-not that I would know about that...lol
    KINGSPORT, TN.
    i,ve got some mounts that work with stock frame horns no modification to truck at all. if it helps you.\
    bob
    the stock horn mounts were gone before me. that said. any other suggestions. please.
    thanks
    If the stock frame horns are gone, you can do what ever you want.
    I would suggest a style that has a plate bolted to the block of the engine. Channel iron or something of similar strength running out to sit on top of the frame rails. With a round rubber mount to cusion the mount and a bolt through the mount and frame.
    KINGSPORT, TN.
    fab time then ...........
    Northern Colorado
    If you can get some FSJ AMC V8 motor mounts, you might be able to find a Chevy adapter. Or, look for a Chevy adapter for the CJ's that used to have AMC V8's.
    The FSJ motor mounts literally bolt in, so I'm told by the guy who did my engine conversion.
    Jan 2007
    Fort Smith, Arkansas
    I have an 83 chevy truck I'll be scrapping soon. If you want the chevy frame mounts, lemme know. The shipping should be reasonable, the parts are free. Of course it'll require some mods to the mounts and then welding them in.
    Fayetteville N.C.
    Advance adapters has the wide Jeep frame small block conversion mount kit. All you have to do is either bolt or weld the frame plate to the frame. Comes with the block mounts, the frame plates, and the rubber insulators w/bolts.
    RH
    67' M715
  1. Top speed with a small block chevy?
    By cnewman425 in forum Open Discussion
    Last Post: April 19th, 2011, 02:20 AM
  2. Small Block Chevy Swap
    By AEM67M715 in forum Modified Tech
    Last Post: January 7th, 2010, 02:11 PM
  3. Small Block or Big Block Chevy Swap
    By jrok93003 in forum Modified Tech
    Last Post: April 28th, 2008, 03:47 PM
  4. another small block chevy question
    By da mule in forum Modified Tech
    Last Post: September 24th, 2007, 09:40 AM
  5. Headers for a small block conversion?
    By beafire1 in forum Modified Tech Archives
    Last Post: May 1st, 2004, 10:11 PM
