Results 1 to 3 of 3
Thread: Is it possible to connect a converter to ignition coil
    RubyRed Guest
    Default Is it possible to connect a converter to ignition coil
    I had an Ignition coil burn up on me and I was wondering if it is possible to connect a converter to the ignition switch and use a 12 volt coil instead?
    If you take a 24 to 12 volt converter capable of handling 5 amps max and wire it in correctly, yes, that would be a do-able thing.
    Hook the converter to the battery.
    Gonna need an on/off switch for the ignition or a key switch.
    Run the positive output from the converter to one side of the new switch then from the switch to the coils positive terminal.
    Run the negative output of the converter to the points.
    Run a wire, already there really, from the points to the coils negative terminal.
    Now you have a 12 volt ignition.
    Just get a converter that is rated for continous duty. It really sucks to have your ignition go out 40 miles from home on a 100 degree day. Just ask porkchop. We wired the coil directly to one battery and got ourselves home.
  1. New coil
    By Anson in forum Stock Tech
    Last Post: February 20th, 2020, 10:33 AM
  2. 24v to 12v converter
    By chicklin in forum Modified Tech
    Last Post: January 7th, 2009, 06:31 PM
  3. 24 v coil
    By jcmitch10 in forum Stock Tech
    Last Post: October 16th, 2008, 09:28 AM
  4. Coil
    By ptjeeper in forum Stock Tech
    Last Post: November 1st, 2007, 11:38 PM
  5. 24 Volt Replacement Ignition Coil
    By law in forum Stock Tech Archives
    Last Post: May 12th, 2004, 12:33 PM
