Old April 5th, 2010, 03:39 PM
DivingKaiser's Avatar
DivingKaiser DivingKaiser is offline
Basic Trainee
DivingKaiser is a Soldier
Default Brake line diameter??
Thanks for any answers! Installing a hydroboost system for the brakes.
Replacing all the steel lines, however what diameter should be used, or does it even matter? Do I use the line diameter for the hydroboost from the vehicle it came out of? Or for the brake system it is for (Chevy parts).
I know the smaller diameter will give more psi (theortically) and the bigger will give more volume, wondering about heat build up, psi volume to the pistons etc...
Thanks,
Dave
Old April 6th, 2010, 04:23 AM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
In a semi-static system as a brake line, line diameter will have no effect on pressure. If you have drum brakes, you need a bit higher flow rate, so I would use 1/4" lines, rather than 3/16".
fisherman : Brake line pressure switch for brake lights. fisherman PseudoZone - Open Archive 12 November 11th, 2009 09:33 PM
Brake Line Tools Tomahawk715 Modified Tech 10 November 1st, 2009 09:01 PM
Brake Line Problem? fisherman Modified Tech 14 October 2nd, 2007 07:13 AM
brake line to master cyl. ?? Elohim1 Modified Tech 4 February 8th, 2007 09:00 PM
Brake Line Routing Question!! Nuke_spicergear Stock Tech Archives 2 May 25th, 2004 06:18 PM
1998 - 2019
Copyright 1998-2019
