  #1
Old February 10th, 2019, 03:01 PM
Swampthang's Avatar
Swampthang Swampthang is offline
Private 1st Class
Swampthang is a Soldier
Default Flat front leaf springs
I haven't posted in a long time, life got in the way of living. I'm resurrecting my project after a several year hiatus and have a question about front leaf springs. Does anyone know of a flat or slightly arched spring pack that would be a direct replacement for the front spring pack? I'm using an 80's Ford king pin 60 and 14 bolt G.M. van rear which are exactly the same perch measurements as the stock axles and are only 1/2" different in track width from each other. However, the front D60 has to be mounted spring over because the pad is cast into the differential. I'm looking for a pair of springs that would level the truck back out.
  #2
Old February 10th, 2019, 04:24 PM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
I thought about pursuing this and I would call alcan or deaver or some other custom spring shop....The likelyhood of finding a stock swap has got to be nill, but I am in for the answer...
__________________
Is that real money?
  #3
Old February 10th, 2019, 04:57 PM
jhartings jhartings is offline
Private
jhartings is a Soldier
FYI...
Previous thread on same subject
Stock leaf spring?
  #4
Old February 11th, 2019, 09:21 AM
venominjected's Avatar
venominjected venominjected is offline
Corporal
venominjected is a Soldier
I welded SUA perches and ground/welded on the center section with Hi-Nickel rod (pre and post cooling for cast steel also)
1988 F350 Dana 60 kinpin (same as you)
Just finished the rebuild post welding/fitment.
Also used the matching F350 rear axle also and did a disc conversion.
__________________
  #5
Old February 11th, 2019, 04:48 PM
Swampthang's Avatar
Private 1st Class
That's a really nice build. I'd considered that, but was worried that it might compromise the strength. Plus, my welding skills are less than stellar.
  #6
Old February 11th, 2019, 04:52 PM
Swampthang's Avatar
Private 1st Class
I may try removing some leafs and see how it looks.
1998 - 2020
Copyright 1998-2020
