Old August 25th, 2007, 10:10 AM
Calpyro's Avatar
Calpyro Calpyro is offline
Calpyro is a Soldier
Default Headrest modification on stock seat
I was asked for some photos of my modified seats. In summary, I drilled holes in the stock seat backs, welded some tubing in the frame and fabricated the head rests from plywood and steel. Added soam padding and covered it with Mil Spec canvas. Pretty easy project.
Another modification was to the seat adjustment mechanism. I cut off the stock slide bolts and added my own that allowed the seat to slide beck further to increase the leg room for the drivers seat. It prodvides for about 3"-4" of additional leg room.
M715 W/W, M37
Old August 25th, 2007, 06:23 PM
k8icu's Avatar
k8icu k8icu is online now
Sergeant
k8icu is a Soldier
So the head rest is removable? If so how do you keep it secure when it is in?
Nice modification Keeps everything stock, yet still GI even with the mod...I like it!
Zone holster maker
Old August 25th, 2007, 07:15 PM
Calpyro's Avatar
The rod from the head rest is about 1/4" longer that the tubing and it has a small hole for a cotter pin. It fits pretty securely even without the pin.
M715 W/W, M37
Old August 27th, 2007, 08:27 PM
fisherman's Avatar
Sergeant
fisherman is a Soldier
Great pictures, thanks. Now I have some ideas, where did you get the canvas from, the same place you ordered your seat covers? How much did the extra canvas cost?
Old August 27th, 2007, 09:40 PM
Calpyro's Avatar
I got the seat covers and extra from http://www.odcloth.com/ . As I recall, the scraps were less than ten dollars.
One thing I forgot to add is that I covered the back of the headrest with a panel of 1/4" plywood, with canvas glued to it. The panel was then screwed to the headrest. The panel hides the seams and staples.
Hope it helps.
M715 W/W, M37
Stock seat project fishtail Stock Tech 54 August 30th, 2016 06:53 PM
Stock seat covers da mule Stock Tech 2 July 7th, 2009 07:34 AM
seat help willy Open Discussion 10 January 13th, 2008 08:28 PM
Wiper blade that fit without modification Calpyro Stock Tech 0 September 16th, 2007 11:06 AM
Stock specs for stock axle, wheel, brake drums & tires brute4c Stock Tech Archives 0 May 31st, 2007 06:46 AM
1998 - 2019
Copyright 1998-2019
