Results 1 to 2 of 2
Thread: 12 volt tach, 24 volt system
    Default 12 volt tach, 24 volt system
    I have a 12 volt tach that I use on my engine run in stand. I'm thinking that once I am done with the engine breaking for my 914, I will put that tach on the M715.
    Will running the wire to the negative coil (as per usual) work for a 12 volt tach, or will it overload somehow. I don't THINK it will, but I am horrible with electric stuff.
    Zach
    Quote Originally Posted by vacca rabite View Post
    Zach
    Most aftermarket tachometers have 4 wires. The green is usually negative coil connection, the red is switched battery +, the black in ground and the white for the light. All the connections work the same with 24 volts and the bulb can be changed, but, you still have to run the positive lead of the tach to the ignition switch lead, so it would have to be 12 volts, or a 24 volt tachometer.
  1. truckin : why 24 volt?
    Last Post: November 11th, 2009, 04:05 AM
  2. 24 volt lights
    By VAHILLBILLY in forum Open Discussion
    Last Post: October 31st, 2009, 10:24 AM
  3. 24 volt Generator
    By Team Nefarious in forum Open Discussion
    Last Post: September 23rd, 2008, 06:24 PM
  4. 12 Volt Starter
    By bradley in forum Modified Tech
    Last Post: July 22nd, 2008, 06:05 PM
  5. Need 24 Volt Bulbs
    By viperman in forum Stock Tech
    Last Post: February 7th, 2008, 01:45 PM
