Results 1 to 10 of 10
Thread: painless wiring harness?
    Jul 2008
    Saginaw Michigan
    Thumbs down painless wiring harness?
    I am getting ready to swap in a small block and a flaming river column with the gm plug. My question is would a CJ preterminated harness work on these trucks? I am going to do a complete 12V conversion. I know I will have to change all the gauges and the headlight switch. The column already has the turn signal lever. I assume this will be the fastest way to get the truck back on the road.
    Richboro,Pennsylvania
    I would imagine that the wires would be way too short...
    Ditto.
    I bought a harness for a full-size Chevy pickup and it was just about right.
    A CJ harness would provide what you need circuit-wise, but it would definitely be physically too short to get out to the core support for the headlights and of course to the taillamps.
    Jul 2008
    Saginaw Michigan
    Thanks for the input. I will just get the full size chevy harness. As for the column. I like spending money on new parts lol.
    Cut the old column on both sides of the firewall, clean up the edges with a file and your new column will slide right through. Then just bolt the upper mount to the dash.
    I didn't use a pre-made harness, but I did used the Flaming River tilt column with the Gm plug.
    Jun 2007
    Alexandria KY
    Good clean execution and nice pics,,,,
    '67 M715 '42 GPW '45 MB
    Jul 2008
    Saginaw Michigan
    Thanks for the pics. That looks great. Do you know the part# for that, or the length and diameter?
    Here they are. The steering column and the u-joint that hooked it to the steering shaft.
    FLA-FR1714DD CV JOINT
    FLA-FR20007 STEERING COLUMN
  1. tomahawk715 : Painless wiring
    Last Post: December 15th, 2009, 08:22 PM
  2. Turn signal switch/painless harness
    By Craig Merrill in forum Modified Tech
    Last Post: March 9th, 2009, 11:41 AM
  3. New wiring harness
    By fng in forum Stock Tech
    Last Post: February 10th, 2009, 09:53 PM
  4. Aftermarket Wiring Harness - Painless Type
    Last Post: November 19th, 2008, 04:50 PM
  5. Wiring Harness
    By Barrman in forum Open Discussion
    Last Post: March 5th, 2007, 02:56 PM
