Results 1 to 5 of 5
Thread: Were "Chokes" a dealer option?
  1. Default
    I have an "Engine Stop" pull out on the lower dash-rightside of steering column, but NO Choke pull out anywhere? No cable or linkage to carb. either. Just curious, it mentions them in the manuals???
    1969 M715
    That is your choke, The Fire Dept just stuck a duece engine stop on in place of the choke handle. The stock one is just a simple round knob
  3. Default
    Weird! It doesn't work like a Choke,it's like a ratchet mechanism.You have to turn it to make it go back in?
    1969 M715
    That is how the engine stop works. Locks in position. Nothing to do with the choke.
    Could it be a manual throttle with the wrong knob on it...they work that way, with clicks as you pull out and turn to release back in again...where does this thing hook up to? Anywhere or no?
  1. Mike's Restoration Thread, "The List", Current Progress...
    By BubbaWilkins in forum Open Discussion
    Last Post: January 27th, 2011, 03:24 PM
  2. What color is your "Caution Max Speed" plate?
    By AVL Jeeper in forum Stock Tech
    Last Post: August 27th, 2008, 10:39 PM
  3. Brake hose and throttle cable "clips"
    By rboltz in forum Stock Tech
    Last Post: December 5th, 2007, 08:35 PM
