Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 130
Thread: Axles that can be swapped in place of the stock axles
  1. #101
    Quote Originally Posted by venominjected View Post
    You'll just need to potentailly rotate the calipers below the springs... thats what I have to do with my 10.25 Sterling Rear axle
    Cool thanks for the pictures. So it looks like the leaf springs are innthe stock m715 outboard location? Is the sterling 10.25 the same width as the 14 bolt?
    What did you do to clear the front rotors and calipers?
    Sent from my GT-N8013 using Tapatalk
  2. #102
    Nov 2009
    Greenwood, Indiana
    I dont have any real good pictures, but I used a 14bolt from a 73 K20 pickup, clocking the brackets:
    http://www.m715zone.com/vb/showpost....&postcount=135
    Thanks, George
    Joshua 24:15
  3. #103
    Quote Originally Posted by Flingarrows View Post
    So you used a 14 bolt with the disc brake conversion kit from offroad design and rotated the bracket down to clear the m715 leaf springs which are in the stock outboard of the frame position? What did you do about the front gm dana 60?
    Sent from my SM-G900V using Tapatalk
  4. #104
    Quote Originally Posted by res0wc18 View Post
    Read through your build thread nice work. Youre using a dana 44 front still I believe but if the model you have is very similar to a gm dana 60 question is still open...does a cucv k30 srw gm dana 60 need working over to put in the front of the m715 with the leaf springs in the stock location? Or just move the spring perches?
    I think you pretty much cleared up them questions about the 14 bolt. Disc conversion rotate the bracket down to put them below the stock outboard m715 leaf springs, weld the spring perches in the new location and youre good to go? I believe?
  5. #105
    Nov 2009
    Greenwood, Indiana
    Correct on all! I'm not sure on the 60 front. That will be a year or so down the road for me
    Thanks, George
    Joshua 24:15
  6. #106
    Awesome. I forgot to mention that all of this will be a spring over setup just like the chevy is from the factory but with a little less stiff springs ha.
    So the rear 14 bolt is cleared up. Rear disc conversion, rotate calipers down and weld perches in new location.
    So on to the front gm dana 60 srw from a cucv l, the unsolved issue.
  7. #107
    Its been discussed on here before... i think there was pictures somewhere earlier in the thread.
    Google image search: "M715zone Dana 60 spring over"
  8. #108
    Well I've looked over everything on the issue of mounting a gm srw dana 60 front. Since the springs are directly under the frame on the m715 in the front axle location not outboard i think it should work by moving and reeling the spring perches.
  9. #109
    I'm running a axle out of a one ton chevy express van. Direct bolt in, I have disk brakes on all corners, and the van axle has a government locker in it. I made a bracket under the cab to connect the original parking brake lever and rod to the rear cables. Parking brake works good and my truck will stop on a dime.
  10. #110
    Feb 2013
    Wills Point, TX
    Quote Originally Posted by Patriot Paratrooper View Post
    what year of van did you use for donor?
  1. porkchop : 4:10 gears in the stock axles
    By porkchop in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 12:07 AM
  2. Replacing stock axles
    By 4X4jeepfreak in forum Modified Tech
    Last Post: January 28th, 2009, 09:10 PM
  3. stock axles with 44s???
    By guswheels in forum Modified Tech
    Last Post: April 6th, 2007, 07:34 PM
