Results 1 to 3 of 3
Thread: Flasher unit
    Default Flasher unit
    Hi all my flasher unit is shot, its the black oblong plastic thing in the circuit box under the hood. are they a standard unit fitted to other vehicles or not,as I live in New Zealand I have not seen this type before, also who stocks them in the U.S.A. thanks
    Feb 2009
    Northern California
    If this is the electromechanical flasher in the big box with three relays and a resistor, you should be able to replace it with any 24V flasher from an auto parts store. If you want to take a photo of the box and the part, it'll help us know what you're looking at.
    --Randy
    Feb 2004
    N.W. Ohio
    If its the black bakelite flasher.... I had one that didn't work. So I unplugged it & carefully removed the little cover on one side. Then I cleaned the contacts inside. Reassembled & it has worked fine ever since.
    This was 8-10 years ago.
    Darryl
  1. Solid State Flasher Box Test
    By Barrman in forum Open Discussion
    Last Post: August 2nd, 2011, 09:58 AM
  2. Unit ID Help
    By BigDog in forum Open Discussion
    Last Post: July 13th, 2009, 10:33 AM
  3. Modifying stock flasher system
    By dummy in forum Open Discussion
    Last Post: February 25th, 2007, 06:05 PM
  4. Socket for turn signal flasher
    By bdial in forum Stock Tech Archives
    Last Post: May 4th, 2004, 12:48 PM
