Results 1 to 10 of 10
Thread: Aftermarket Seats
    May 2007
    Siloam Springs, AR
    Default Aftermarket Seats
    I need some help from someone with a soft top. I need a measurement from the floor pan to the lowest point of the roof so I can see if me sweet find on seats will work in my truck. These babies were free and have full spring suspenion with recline, armrest and manual lumbar.
    You will need to know if the seat and our legs will fit under the steering wheel
    Jan 2007
    woodland ca
    i cant get a exact measurment, but its high. really high, im 6' 3 and i have a good foot or so till i hit the roof
    my signature is sweet huh?
    And you don't want the seat too high or you will be looking at the top of the windshield frame.
    May 2007
    Siloam Springs, AR
    The suspension part of these seats is about 3 inches taller than the original frames when fully raised. Just sitting in the them made the frame hieghts match when I tried them out. Plus I am switching out the steering wheel after I get my power steering done so I think leg room will be good. I am just worried about roof clearance right now.
    Port Orchard, Wash.
    There's a ton of room under the top bows. I can pull a measurement for you a little later if no one beats me to it.
    -- Tim Taylor
    The stock seat cushion is about 8-10" off the floor, so that puts me at about mid windshield when sitting in the drivers seat at my 6'0" height. There is still plenty of room above me.
    Port Orchard, Wash.
    Okay, I've got a completely stock driver's seat setup, complete with stock springs, horsehair and canvas cover. (A real comfort treat that, let me tell ya!) And a stock steering wheel, stock canvas bows, etc. Here are the actual measurements I just took:
    Cab floor to seat top at front edge of seat: 13"
    Seat top to bottom of steering wheel: 5-1/2"
    Seat top to underside of top bow, measured from near the back of the seat: 40"
    Seat top to underside of canvas top, measured from the front edge of the seat: 37-1/2"
    Cab floor to underside of top bow: 52-1/2"
    The seat slopes downward a bit at the back while the canvas top slopes downward a bit from the top bow to the top of the windshield, hence the 40" to 37-1/2" measurements. From where your head would be, it would be closer to the 40" position.
    Hope this helps!
    -- Tim Taylor
    When I had the stock seats in mine, I looked just below the windshield seal at the top edge of the glass...I'm 6'6".
    May 2007
    Siloam Springs, AR
    Perfect...The seats are right at 45" fully extended. Thanks for the help...
  1. New seats 68+77+ Corbeau's equals perfect fit seats.
    By kingjason in forum Modified Tech
    Last Post: January 9th, 2010, 09:08 PM
  2. elohim1 : Lets talk about aftermarket seats
    By Elohim1 in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 05:38 AM
  3. Aftermarket seats and mounts
    By Grantshire in forum Modified Tech
    Last Post: June 1st, 2008, 07:22 PM
  4. Best Aftermarket Alternator?
    By fwdstuck in forum Modified Tech
    Last Post: June 29th, 2007, 02:24 PM
  5. Aftermarket Gauges?
    Last Post: March 17th, 2007, 09:29 PM
