Results 1 to 6 of 6
Thread: Shorten stock wheelbase? Pros,Cons,Personnel Experience?
    Default Shorten stock wheelbase? Pros,Cons,Personnel Experience?
    Hello, I don't post much but was interested in any input on shortening the stock wheelbase on my 715. About 7 yrs ago I rehabbed it mechanically and put in stroked SBC with ranger OD, PS, PB, 12v, 38" SSs ect ,ect. Posted alot on the old site back then but have kinda lurked here last few yrs. Kinda lost my inspiration with the truck so was thinking of shortening it up so the rear wheelwells would be right behind the cab and tailgate right behind that. Found a couple short clips on youtube showing a short 715 but can't find out anything else. Thanks in advance for any input, have a good weekend
    Jester Guest
    Jester Guest
    Doug shortened his quite a bit...has a few vids on you tube so I am guessing it might be his...
    If I recall it right, he took out 15 inches in front of and 15 behind the axle and then made new sides that look like the bed sides but arent really...its interior is like a CJ or so...one unit from dash to tailgate...
    Jon's right about the dimensions. New wheelbase of 111"
    I built a new frame for the back half of the truck to insure axle clearence...I stayed spring under. If you just move the axle forward, it's starts getting close to the frame and clearence could be an issue.
    I found Doug's bulding threads....looks pretty good, I didn't think about "Unibody" CJ aproach he used. I was going to shorten the frame and bed themselves. I helped shorten an IH 3/4 ton years ago. Owner used "fish plates"(?) to weld over the welded up frame joint. Also cut frame at an angle so joints would be longer and stronger. The plates were 1 1/2 ft long or so with each end pointed so kinda looked like a oblong diamond shape.
    Trying to talk myself out of it but I think it would be a cool mod. Thanks for everyones comments.
  1. binfordm715 : Ford 300 swap, pros and cons.....
    Last Post: November 11th, 2009, 03:29 AM
  2. Shorten the Wheelbase?
    By white433 in forum Open Discussion
    Last Post: July 13th, 2009, 09:49 PM
  3. Pros & Cons of the Stock Braden winch?
    By dukhunter785 in forum Open Discussion
    Last Post: December 19th, 2007, 11:13 PM
  4. Pros and cons wanted
    By rjenkins in forum Modified Tech
    Last Post: January 25th, 2007, 01:08 PM
  5. Personnel Heater
    By Michael in forum Stock Tech Archives
    Last Post: January 18th, 2004, 12:41 AM
