Results 1 to 4 of 4
Thread: what does it take to put a ford 390 in a 715
    Default VPW
    i have a built ford 390gt i wont to put in my 715 and was wondering what it needs
    May 2004
    Central Wisconsin
    Lets see..
    Assuming you had fabrication skills it would be rather simple. Build some motor mounts, either adpat the 390 bellhousing to the T-98, swap in a 2 wheel drive Ford T-18 or a 435, or use an automatic fixed yoke C-6 from a high boy Ford 4x4 pickup. thats assuming you wanted to retain the Np200 Divorced transfer case now in the M-715.
    If you wanted a "married case" then you would need to use those components..from a truck so eqipped.
    basically a donner 4x4 of the transfer case style you wanted with an FE engine in it would provide most everything you would need with the exception of the motor mounts, those you would most likely have to fabricate to get correct engine placement.
    I would think it would make for a nice swap actually...and if we could toss a 428 in a Ford Ranger...a M-715 shouldn't be to hard at all.
    NoRM
    If I remember right, Drew put in a 460 using 390 motor mounts and needed only to oval the mount holes in the stock 230's frame horns....so mounting the engine should be pretty easy....
    After that it depends what your gonna use...
    thanks for the info.
  1. What does it take to ford?
    By buzzbike71 in forum Stock Tech
    Last Post: May 22nd, 2011, 12:35 PM
  2. ford 300
    By RJBM715 in forum Modified Tech
    Last Post: November 23rd, 2009, 05:42 PM
  3. ford 300 help
    By FullBird in forum Modified Tech
    Last Post: July 18th, 2009, 04:59 PM
  4. Ford 300
    By CTM in forum Modified Tech
    Last Post: January 11th, 2009, 07:38 PM
