Results 1 to 10 of 17
Thread: Part Numbers
    Default Part Numbers
    The parts numbers list is down in the manuals section of the Zone. Does anyone have the NAPA numbers for tune up items, such as oil filter, fuel filter, points, condenser, and rotor? Original 230 engine. Anything else that might be helpful.
    Thank You.
    May 2004
    White Mtns of N.H.
    NAPA 1515 Oil filter
    Condensor = AL869; Points = CS725A; Rotor = AL166; Plugs = NAPA2344
    Please verify all.
    Default Thanks
    Thanks guys!
    I went to Napa monday and got all but the rotor, the number did not come up in the system. (AL166) Any other ideas?
    Mot-Man
    That is the only number I have.
    Here is what my records show. All these parts were bought from NAPA back in '04.
    Condensor = AL868; Points = CS729A; Rotor = AL107; Plugs = 6-295 Autolite; Cap = AL128.
    See if that rotor number comes up.
    68 M-715
    67 M-725
    Thanks, I will give it a try.
    1969 M715 W/WN
    Quote Originally Posted by rpgdeity View Post
    Where did you get that number, and have you installed that part or is it sitting on a shelf in the barn for later?
    Uh, hang on a second. I just realized something. I thought you were talking about the civvy 12 volt distributor. Is this correct or are you still running the mil 24V one? I saw where you said original 230 engine, thought you said civvy dist. as well. Could you please clarify Mot-Man-616?
    68 M-715
    67 M-725
  1. Part numbers that may help???
    By SouthernM715 in forum Stock Tech
    Last Post: June 26th, 2013, 11:29 PM
  2. Part Numbers for drums??
    By 1BadKaiser in forum Stock Tech
    Last Post: August 9th, 2009, 10:52 AM
  3. Brake Part Numbers
    By clearingcrap in forum Stock Tech
    Last Post: June 8th, 2009, 10:37 AM
  4. Part Numbers...
    By Enigmatic in forum Open Discussion
    Last Post: September 17th, 2008, 10:20 PM
  5. part numbers
    By Nuke_afftaburner in forum Stock Tech Archives
    Last Post: May 7th, 2004, 03:01 PM
