Results 1 to 10 of 12
Thread: Dana 70 35 spline spider gears
    New Haven, CT
    Default Dana 70 35 spline spider gears
    Hello,
    How difficult is it to get spider gears for a M715 D70 carrier, but in 35 spline? Are these readily available?
    Also, can I change the yoke in that D70 to a 1410 without having ot replacing the crush sleeve? Is there anything else involved?
    Thanks,
    Mikel
    Quote Originally Posted by Mikel View Post
    Hello,
    Thanks,
    Mikel
    i could be all wet here, but as far as i know the dana axles for the most part use pinion preload shims. once they are set, they are set. you can pull the yoke as much as you want. i would change the seal and always use a new pinion nut. as for crush sleeve style, you can leave the sleeve, you just have to be carefull not to over crush it when you re-install the yoke. i have done this to more than one rig, and i am not sure how correct it is, but i haven't had any issues with it.
    67 #18820 mostly stock...
    Winlock, WA
    Most d70 spider gears are already 35 spline, so that should be an easy junk yard find.
    Only thing, is the hole in the side large enough? About 99% sure it is, but something to check on.
    As for the yoke, I have done it a number of times without issue.
    Get a new pinion nut when you put the yoke on. Even though I have reused those, they are supposed to be a 'one time only' kind of thing.
    I do KNOW that reused ones always end up loosening up on me though. Took a couple times of tightening it, for it to finally dawn on me
    New Haven, CT
    Quote Originally Posted by Hammer View Post
    Hello,
    I believe the splines in the M715 23 sp shafts are 1.500" in diameter, same as the 35 spline shafts, so the hole should not be a problem.
    Thanks,
    Mikel
    The stock axle is 1.375 as just measured in my shop...
    New Haven, CT
    At the splines or at the shaft?
    Shaft...hmmm...will measure the splines...
    Yep, you are correct!
    Little bit of widening just before the splines...1.5 inch diameter in the last 2 inches or so.
    Winlock, WA
    Whew, I was hoping that was the case.
    I remember that they necked down a bit, but I couldn't remember if the hole in the carrier was the same.
    I know that WillieM715 had done this swap like 10 years ago. And he said it all just bolted in. But I couldn't remember if there were any parts he needed to modify.
    Aug 2007
    central central wisconsin
    So, what would you get the axle shafts from? or is this strictly a custom axle shaft deal?
  1. Dana 70 gears
    By xownzux in forum Modified Tech
    Last Post: May 26th, 2011, 07:05 AM
  2. Front and rear end spline count ?
    Last Post: March 31st, 2010, 10:48 PM
  3. dana 70 gears
    By bggrntrk in forum Modified Tech Archives
    Last Post: May 21st, 2004, 01:32 PM
  4. How to convert the front Dana 60 to 35 spline axles
    By brute4c in forum Modified Tech Archives
    Last Post: March 15th, 2004, 10:45 AM
