Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: only1jp : more engine swap ?'s
    Default only1jp : more engine swap ?'s
    Post by only1jp on May 13, 2006, 9:24pm
    Has anyone done an electric windshield wiper conversion? I'm considering doing an electric vacuum pump to run the factory wipers, but that may prove a much more pricey venture than it's worth. Also how difficult was the switch to make? I was also wondering about radiators and fans, I am leaning more towards an electric fan with a new crossflow radiator w/dual fans if there's enough room. Does anyone know what fits or a kit that's available? How about pics of your swap? By the way, I started to assemble my 383 stroker today! Got all of the plastigage done, clearances in the mains and rods look perfect. I will say that spiral lock pistons are hard on the fingers!! Ran into a small snag though, didn't realize my rings are file to fit, wouldn't you know, nobody has a piston ring file...... ggrrrrr
    Port Orchard, Wash.
    Default binfordm715 :
    Re: more engine swap ?'s
    Post by binfordm715 on May 13, 2006, 11:44pm
    I think Al (kaiserjeeps and/or thetroublemaster or something like that) has done the electric wiper swap on his CJ-5 using a marine wiper or some such. But that was using an electric motor to run the wipers themselves, not a vacuum pump.
    Mar 2004
    northern Arizona
    Default compexp :
    Post by compexp on May 14, 2006, 10:04am
    Looking at the cowls and such, it appears that the civilian wipers would mount up. the only issue would appear to be that the mil windshields are flat, and the civvies curved, but i think a slight "modification" to the wiper arm to remove some of the curve would work.
    I was unable to try this on mine because I stupidly mounted my fuse panel in the middle of the dash behind the gauges. doh!
    I got a couple of electric motors from AB and they work, but not really well. I think PCs marine motors sound like a good if pricey option
    Default brute4c :
    Post by brute4c on May 14, 2006, 1:29pm
    I used the JC Whitney wiper motors in 24 volt...they bolt right in and the wiper arm sold with them work fine on the flat windshield.
    They have one for $29.99 and $39.99...dont know the difference...
    http://www.jcwhitney.com/autoparts/ItemB....-p_CA TENTRY_ID:100000235657
    http://www.jcwhitney.com/autoparts/ItemB....-p_CA TENTRY_ID:100000235941
    The marine motors are definitely more robust and will last longer as they have metal gears instead of plastic. They also are adjustable for a wider swing arc. They are also more expensive of course...
    Default only1jp :
    Post by only1jp on May 14, 2006, 6:00pm
    brute did you mount them where the stock vacuum wiper motor is located or somewhere else?
    Default brute4c :
    Post by brute4c on May 14, 2006, 6:25pm
    They fit in the stock holes with no modifications. The pattern on the M715 is the same "universal" pattern used on cars and trucks back in the 30's-60's. Not the brand specific kind of course...there are lots of vehicles that used them...
    Default only1jp :
    Post by only1jp on May 14, 2006, 7:09pm
    Sweet! Sounds like a much more economical way of getting operational wipers than the 12 volt vacuum pump, I was considering!
    Default k8icu :
    Post by k8icu on May 14, 2006, 7:41pm
    I would like to get my hands on the electric wipers used in the M35A3. I would think those would be the cats PJs. Does anyone here have any info on them?
    Default brute4c :
    Post by brute4c on May 14, 2006, 10:02pm
    Both the JC Whitney and marine type are available in 12 volt as well as the 24 volt...in case you need...
    Default only1jp :
    Post by only1jp on May 15, 2006, 12:11am
    thanx brute! Have any pics of your switch?
  1. 4.0 engine swap
    By no1rifleman in forum Modified Tech
    Last Post: June 22nd, 2021, 02:49 PM
  2. only1jp : engine swap questions?
    Last Post: November 11th, 2009, 12:55 AM
  3. engine swap 230 to 350
    Last Post: October 26th, 2008, 07:15 AM
  4. Engine swap.
    By butch in forum Modified Tech
    Last Post: March 1st, 2007, 07:53 AM
  5. engine swap
    By fhozaly in forum Stock Tech
    Last Post: January 28th, 2007, 08:55 AM
