Results 1 to 10 of 10
Thread: stanman : Vigilante 327 V8
    Default stanman : Vigilante 327 V8
    Vigilante 327 V8
    Post by stanman on Nov 5, 2006, 12:01pm
    Has anyone ever swapped in a Vigilante 327 V8? Just wondering.
    Default porkchop :
    Re: Vigilante 327 V8
    Post by porkchop on Nov 5, 2006, 6:56pm
    Not worth it. I had one in a 67 wag. Lots of torq but finding parts for one is just as hard as the 230, if not harder.
    Default stanman :
    Post by stanman on Nov 6, 2006, 1:47am
    oh. just was wondering if it would be a viable swap
    Washington State
    Default fisherman :
    Post by fisherman on Nov 6, 2006, 1:52am
    You could do it easy enough, as they came in full size trucks and wagoneers for a couple of years, its just an oddball. You might have a hard time finding parts, and pay a premium. Probably be better off going with something newer and easier to get parts for. Lots of other options. If I had one and it was known for sure to be a good engine I probably wouldn't have a problem putting it in. After all I'm going with a Buick 350.
    Default stanman :
    Post by stanman on Nov 6, 2006, 8:09pm
    Would the bellhousing pattern be the same?
    Washington State
    Default fisherman :
    Post by fisherman on Nov 6, 2006, 9:50pm
    Good question, don't know.
    Default brute4c :
    Post by brute4c on Nov 6, 2006, 10:23pm
    There is only 1 engine on Earth besides the 230 that shares the same bellhousing pattern...that is the older 226 flat head 6 cylinder.
    Other than that NOTHING will bolt up without adapters.
    Default alqcca :
    Post by alqcca on Nov 6, 2006, 11:04pm
    Have one in mine that the FD installed.
    The bell housing I assume came with the engine and bolted to the T98
    However a longer input shaft was needed fo the tranny.
    they sold off the truck for that reason.
    The only reason I like it it that it is the v8 that comes from the same year civilian truck.
    Other than that parts are a pain!
    When it goes I'll put the 360 from my CJ in it
    Al
    Default stanman :
    Post by stanman on Nov 7, 2006, 1:10am
    I did a little research on the engine and AMC made 3 versions, the 250, 287 and 327 from 1956 to 1968. But Jeep had them only from 1965 to 1968. One would think that you could find parts but I guess not. Just for kicks and screams, how hard would it be to swap in one? would the motor mounts be similar or totaly differnt?
    Default porkchop :
    Post by porkchop on Nov 7, 2006, 7:22am
    The motor mounts on a M715 look the same as the ones that were on the '67 wag I had. without having them side by side it is hard to say. But I am thinking it should drop right in.
  1. stanman : np201
    Last Post: November 12th, 2009, 05:23 AM
  2. stanman : on board air
    Last Post: November 12th, 2009, 04:28 AM
  3. stanman : tires again
    Last Post: November 12th, 2009, 04:05 AM
  4. Vigilante?
    By ronzello in forum Open Discussion
    Last Post: December 2nd, 2007, 04:31 PM
  5. Vigilante 327
    Last Post: December 24th, 2006, 04:39 PM
