  #21
Old January 23rd, 2004, 11:35 AM
Joel Joel is offline
Joel is an Observer
Default PCV revisited
The grille opening on the M715 looks similar to the grille opening on a CJ. If they are close enough you use a CJ grille cover and cover your grille. They make black ones that wouldn't look too out of place.
  #22
Old January 25th, 2004, 07:13 AM
HUMMER103's Avatar
HUMMER103 HUMMER103 is offline
HUMMER103 is an Observer
I was down at the junk yard on friday pulled a steering box and a master cylinder/brake booster out of a Grand Wagoneer with a 360 in it. It seemed like the radiator uses a similar mounting system to the stock M715. Im in the middle of my project and was thinking this might be a great way to cool my chevy 350. Will this swap work?
  #23
Old January 25th, 2004, 09:31 AM
Nuke_rcassettyjr Nuke_rcassettyjr is offline
Basic Trainee
Nuke_rcassettyjr is an Observer
Default Body Bushings
Not without mods. The GW radiator is too wide. You would have to move the core supports out to fit the wider radiator or swap in the rad support from the GW to fit it. IIRC, aren't the AMC V8 radiator inlet/outlet in the wrong place for the 350?
I would try a CJ radiator set up for converting to the 350. It should be an almost bolt in (drill some new holes in the flanges) and lots of people do 350 swaps in CJs so they should be common.
I am going to use a 4 core CJ V8 radiator for the AMC 360 swap in my 715 (new and local for $210).
Good Luck.
HTML code is On
Radiator Mikel Stock Tech 13 October 18th, 2009 08:23 AM
radiator help! werd Modified Tech 4 May 24th, 2009 05:59 PM
Again with the radiator Tomahawk715 Modified Tech 6 October 23rd, 2007 11:47 AM
Radiator for V8? randyscycle Modified Tech 17 July 22nd, 2007 06:02 AM
