Results 1 to 4 of 4
Thread: my stupid wiring question
    i have a new wiring harness. is there anything i need to watch out for as far as wires? can i reuse all the generator wires and such??? any need to be beefed up for 12 volt use???
    Lee,
    Do you mean that you have a NOS M715 harness? Or do you have a new generic harness?
    new M715 harness, as in made last year with waterproof connectors and all
    Add fuses, LOTS of fuses. Stock M715 harness didn't have any.
    Also, add a main fuse or circuit breaker between the harness main BAT feed and the battery/starter and also between the alternator output and battery/starter. Circuit breakers are nice because they double as a manuall shut off switch. For a stock M715 harness, make the main fuse for the harness no bigger than 60a. For the alternator fuse, size it to the alternator peak output +10 to 25%. BTW, the alternator fuse is not to protect the alternator -- it is to prevent an electrical fire if the alternator fails and shorts out!
    -Mudog
    '67 M715 #165
    521ci SFI BBF, 4R100/NP203/NP205
    GM D60 ARB/10.5" Det/5.13s/11.00-16 XZLs
  1. Potentially Stupid Question: Spicer Hub O-rings
    By Mudog715 in forum Modified Tech
    Last Post: November 26th, 2009, 05:59 AM
  2. stupid rockwell question
    By rustwagon in forum Modified Tech
    Last Post: January 26th, 2009, 05:23 AM
  3. mileage - a stupid question, perfect for me
    By jay r in forum Open Discussion
    Last Post: June 15th, 2008, 09:00 AM
  4. stupid question
    By mojomot in forum Open Discussion
    Last Post: June 24th, 2007, 08:31 PM
  5. Stupid Newbie WINCH question???
    By Nuke_Danarchy in forum Open Discussion Archives
    Last Post: March 19th, 2004, 12:45 PM
