Old January 11th, 2004, 05:13 PM
Brian Sisson Brian Sisson is offline
Brian Sisson is a Soldier
Anyone know offhand about a 350's rear main seal installation?
I installed one saturday and the instructions were destroyed before I had a chance to read them. It was a Fel-pro and said something about the thick side facing ________. I read it as it burned in the stove.
I was just hopeing someone knew and I'd not have to buy another to find out.
Thanks,
-B.
Old January 11th, 2004, 05:23 PM
Nuke_GTOPAZ Nuke_GTOPAZ is offline
Basic Trainee
Nuke_GTOPAZ is an Observer
For lack of a better term, there's a lip on the seal that should point to the front of the engine. Not sure what you mean about a thick side.
I don't mean to be too bog a smartass, but are you STILL rebuilding that engine or is this a new one?
Mine just keeps getting taken further apart.
Maybe it\'s all the beer.
Old January 11th, 2004, 05:34 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Brian,
Gtopaz is right. I am posting the same answer a different way so you can look at it different ways and get the same result. Your seal is probably gray or black in color. One side is flat and smooth. The other side has an angled piece on it and a checker board or cross hatch pattern on it. The smooth side goes toward your transmission. If in doubt, try loosly fitting it on your bearing cap. It should only fit on one way, the correct way. Remember to 'clock' it some as we covered a few weeks ago. Have fun.
HTML code is On
Rear Main Seal Question drose5432 Open Discussion 8 February 25th, 2009 12:03 AM
rear main seal question Duane Stock Tech 1 December 13th, 2008 01:29 PM
rear trans seal Duane Stock Tech 8 September 24th, 2008 06:17 PM
Rear Main Seal rboltz Stock Tech 19 March 25th, 2008 05:48 PM
Rear Main seal questions Brian Sisson Modified Tech Archives 6 January 6th, 2004 02:50 PM
