Old January 15th, 2004, 05:28 PM
Angry_Truck's Avatar
Angry_Truck Angry_Truck is offline
Angry_Truck is a Soldier
Default Dual master cylinder proportioning valves/distribution block
I am in the process of converting my truck from the stock single cylinder master cylinder to the dual master cylinder. I have picked up the Wagner#F66857 dual type listed in the online manuals but, now I am trying to figure out the proportioning valve/ distribution block.
What proportioning valve/distribution block are you guys using for your dual setups? Someone wrote that the block off a '70 Ford will work. Any others?
Are you using the original brake pressure switch? Or are did you change to a pedal mounted type?
The pipe fittings for this F66857 are much larger than the stock lines. Anybody have any problems with braking performance by using adaptors to reduce the fittings down to the stock lines?
Thanks,
Brian
Old January 15th, 2004, 06:12 PM
CaptainMorgan CaptainMorgan is offline
Basic Trainee
CaptainMorgan is a Soldier
I pulled the distrabution blocks off of an old international. As far as I know they are correct, but I wont know for sure untill I have it trail worthy and can test them real well.
Old January 15th, 2004, 09:09 PM
LuckyPabst's Avatar
LuckyPabst LuckyPabst is offline
Private 1st Class
LuckyPabst is a Soldier
You don't need any prop valves if you're using 4 wheel drums and you've matched that with a drum/drum master cylinder.
Chris
Old January 16th, 2004, 06:37 AM
Private 1st Class
If you're using the Corvette non power unit w/power booster, you dont need a prop valve. I ran the front to a block with the pressure switch and ran the rear master cylinder outlet to the rear of the truck. Fresh turned drums, new pads, and she'd lock up all four 37x13 boggers on blacktop.
Big Blocks RULE!
HTML code is On
Dual Master Help rboltz Modified Tech 20 June 22nd, 2016 07:40 AM
Bleeding that dual master system rboltz Modified Tech 7 September 5th, 2009 08:44 AM
Dual Master In! rboltz Modified Tech 3 August 17th, 2009 01:48 PM
m-715 master cylinder upgrade razrbacman Open Discussion 15 May 2nd, 2008 05:09 PM
master cylinder Q. kaiserkoski Stock Tech Archives 7 April 27th, 2004 06:40 PM
