Results 11 to 20 of 23
Thread: spring under lift springs
  1. #11
    it is: get some FSJ springs and modify the spring mounts. Solved! You can thank me later hahahaha
    **I heart Bump_r **
  2. #12
    Winlock, WA
    Just for a note of comparison, 4" lift springs for a FSJ are the same arch as the stock M715 springs. And the fact that they are softer means you will not get the same amount of lift from them. So to possibly gain 1.5" of lift, you could swap to the 6" lift springs for FSJ's. But you either need to change your spring mounts, or wait a while until the newer 6" version comes out for the older FSJ trucks (same mounts).
  3. #13
    GILLETTE WYOMING
    what type of spring mount mods are you guys talking about?switching to another spot on the frame,lowering or widening the mounts????? has anyone attempted a shackle reversal?that would help ride and steering a touch??
  4. #14
    Hey jeeperguy, I'd answer you but the last time you told me that I was narrowed minded ! My truck is set up that way already, but then again what do I know. M1028
  5. #15
    not much, you ignorant American redneck: all your trucks are broken, right? hahahaha
    anyway. I forgot to look at the mounts last time: what did you do to the fronts? I'm going to have to take more pictures next time.
    **I heart Bump_r **
  6. #16
    As far as I can tell, the 715 doesn't share the exact same front spring mounting configuration as any of the other Jeeps. All of the early Jeep trucks, including the 715, had the "post mount" type springs, but that's where the similarity ended. The Wagoneers were spring under, like the 715, but the springs were much closer together. The J-trucks were spring over. BJ's Offroad is currently developing some lift springs for the early post mount Wagoneers, but I doubt they'd do us much good. In the future, they may develop some for the early J-truck, but who knows if they will come any closer to the 715 stuff. I doubt it. The lift kits currently available for the later FSJ's have a completely different mount. Any way you go, you're most likely looking at custom spring mounts for any off-the-shelf spring.
    If you can get custom springs for $180 ea, that sounds like a deal. Like tacoma says, the increased arch won't flex as good as a flatter spring, but the stock springs are so stiff they don't flex at all, so you may actually come out ahead!
    Tony Casey
    BULLGEARInc.com
  7. #17
    GILLETTE WYOMING
    thanks for the input I think I'll giv'em a try and see what happens.......Love that wrecker that's about as rare of a jeep there is do you know production #'s on that old dog?
  8. #18
    the wrecker variants were made from the factory cab/chassis.... fairly rare, but not a factory option.
    **I heart Bump_r **
  9. #19
    Wow! are you guys married or what?
  10. #20
    I've glance through this a couple of times and hope I didn't miss it, but why not pull a couple leaves from the stock pack, then spring over it? Several guys have already posted in the past about the much enhanced flexibility of the suspension with a couple leaves removed and then the spring over would gain you the few inches you want. ?
    Big Blocks RULE!
  1. coil springs and leaf springs ?
    Last Post: April 4th, 2010, 01:13 PM
  2. stock leaf springs vs custom leaf springs
    By japsk8 in forum Modified Tech
    Last Post: December 11th, 2009, 02:02 PM
  3. Lift Springs
    By Troop ISP in forum Modified Tech
    Last Post: September 12th, 2009, 09:27 PM
  4. Replies: 8
    Last Post: February 24th, 2009, 08:09 PM
