  #21
Old February 12th, 2004, 06:05 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Springover with 2 leaves out in the rear, 1 in the front, gives about 5 1/2 inches lift.
Some dont want to do a springover as it will raise them more than they want...center of gravity issues...others just dont want to take on the complexity of it...others want the ability to return to stock...
Probably others, these are off the top of my head.
  #22
Old February 15th, 2004, 11:15 AM
Nuke_jeeperguy/wyo Nuke_jeeperguy/wyo is offline
Civilian
Nuke_jeeperguy/wyo is an Observer
with the spring-over what are the options with the steering arms? I don't want to heat and bend them,what have you guys done on this aspect?what about the pitman arm for that much lift any aftermarket stuff fit?
  #23
Old February 15th, 2004, 01:21 PM
brute4c's Avatar
Grand Poobah
Default from cincy?
On the steering arms, having the ends welded shut and recut from the top with a tapered ream instead of from the bottom like stock is the way to go. Once the taper is there, drill the rest of the straight hole and you got it...I have heard of people just running the tapered ream from the top but for me I would take up the slack of the bottoms bevel with solid weld material.
Pittman arm, this is from the old yahoo board...
QUESTION:
What pittman arm does one use with a springover?
ANSWER:
If your trying to find out what type of dropped pitman arm to use on your Saginaw power steering conversion? Use the dropped pitman arm available out of any 4x4 magazine for a 1980-1988 Ford Bronco. This pitman arm splines onto the Saginaw box and the 715 tierod end is the same diameter as the Bronco's.
Good luck,
HTML code is On
coil springs and leaf springs ? randall555 Modified Tech 2 April 4th, 2010 10:13 AM
stock leaf springs vs custom leaf springs japsk8 Modified Tech 13 December 11th, 2009 10:02 AM
Lift Springs Troop ISP Modified Tech 10 September 12th, 2009 06:27 PM
whats the biggest tires that will fit with a spring over lift randall555 Modified Tech 8 February 24th, 2009 04:09 PM
1998 - 2021
Copyright 1998-2021
