Results 1 to 9 of 9
Thread: Front Axle Bearing and Seal part numbers needed
    Default Front Axle Bearing and Seal part numbers needed
    Hello fellow Zoners,
    This has prabably been covered a million times but I cant find them!
    I need a list of the part numbers for the bearings, races and seals to rebuild the knuckles on my stock M715. I was doing the brakes and they are rough.
    Are they available from NAPA?
    Can anyone help?
    Thanks!
    Mike
    mike@weldedparts.com
    BlessedM715
    John 15:13
    Greater love has no one than this, That he lay down his life for his friends...
    This is from the archives:
    Inner Bearing Oil/Grease Seal (National # 475384 x 54); 2.)
    Complete Knuckle Gasket/Seal Kit (Spicer #706230X) which includes 12 x rear oil seal bolts, 2 x outer metal seal, felt gasket, rubber seal, and metal ring seal.
    Axle seal, front axle: Napa#28474
    Front Bearings:
    Outer-Timken #18790 Rated @2950 lbs.
    Cup #18720
    Inner-Timken #387A Rated @4900 lbs.
    Cup #382A
    Hub Seal, Front: Seal-"CR" #28175 or NAPA #28474 or National #475384-X54
    Thats all I have.
    Thanks Jon!
    As Always you are the best!!
    God Bless...
    Mike
    BlessedM715
    John 15:13
    You are welcome...and remember, God is the best...we just try to imitate Him!
    Jul 2009
    Louisville, KY
    I just looked up NAPA #28474...$82.40, WOW!
    Thanks for all the help!
    Jan 2011
    Fernandina Beach, FL
    I just looked on Amazon. (I got all of my seals for very good prices for the Braden LU-4 winch) $295.89! What the heck???!!!
    Now that the 706230X Knuckle Seal Kit is obsolete, the price has jacked up on just about anything you can find.
    Here is one alternative that I know of:
    https://torqueking.com/product/4936/...0-front-axles/
    Torque King 4x4 - Qa4936 12 Bolt Knuckle Ball Seal Kit For Dana 44hd, 60, 70 Front Axles - $120 per side
    You can buy Pieces of the 706230X kit, but not the entire kit here:
    http://www.northerndrivetrain.com/pr...I-706230X.html
    Sep 2014
    Wichita Falls, TX
    Yeah, those seals are outrageous.
    I "rebuilt" mine with some vinyl upholstery I had in the shop. 2 layers I think. And I've read on here about people using leather.
    I did that 4 or 5 years ago, holding up good.
    We used to use oil-resistant rubber sheet for various purposes in the oilfield. 1/4" thick, IIRC. I bet that stuff about 1/8" thick would work for this application.
  1. rjenkins : Front and rear shock part numbers
    Last Post: November 11th, 2009, 02:23 AM
  2. Pilot bearing needed
    Last Post: March 20th, 2009, 10:51 AM
  3. NAPA part numbers for front and rear wheel bearings?
    Last Post: January 5th, 2008, 11:33 AM
  4. Front axle trouble- bearing nut tool?
    By azNuke_M715Aggie in forum Open Discussion Archives
    Last Post: March 23rd, 2004, 02:54 AM
  5. Part number for windshield seal?
    By monoshock in forum Open Discussion Archives
    Last Post: February 8th, 2004, 09:45 PM
Tags for this Thread
