Old April 6th, 2004, 04:28 PM
Nuke_Danarchy Nuke_Danarchy is offline
Nuke_Danarchy is an Observer
found these 24 volt LED Turn Signal,Taillight,Brake Lights and wondered if anyone had switched yet?
http://www.etruckpart.com/24_volt_leds.htm
1969 M715
Old April 6th, 2004, 05:22 PM
koobster's Avatar
koobster koobster is offline
koobster is an Observer
Default Anyone switch to LEDS ?
tried the tail light this weekend. relly didnt see a change. save your money
Old April 6th, 2004, 05:48 PM
Bummer! I have them in my motorcycle and they make a world of difference.oh well.
1969 M715
Old April 6th, 2004, 06:22 PM
FSJGuy FSJGuy is offline
Private 1st Class
FSJGuy is a Soldier
I have them both front and rear and they're great. (I have converted to 12v) They're sized right to fit in the mil style housing, too. Looks "correct", IMHO. People following you might think they're bright, however. If you have a 12V conversion, you'll need an electric flasher, as the LED's won't pull the amperage load needed to make a bi-metallic flasher work. Or you can just leave a regular bulb in series with the LED, but that sorta defeats the purpose of the low current draw LED light.
Old April 6th, 2004, 06:44 PM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
The army has a Mil led composite light. They look like the "new" style composite, but are half the thickness. A friend of mine put them on a 1/4 ton trailer he was pulling with a tj. The good thing about them is that they work 12-48V. But they are expensive to buy. I would like to find 24V hallogine bulbs to put in my composite turn and tails now that would give some bright!
Zone holster maker
  #6
Old April 6th, 2004, 06:45 PM
Koob-are yours 12 or 24 volt?
1969 M715
  #7
Old April 7th, 2004, 05:01 AM
Private 1st Class
The military also has a heavy aluminum light housing that looks like our composite ones that houses and led system. I pulled a set off of my M1?? deuce trailer when I rewired it. Should be 24 Volt.
Big Blocks RULE!
  #8
Old April 7th, 2004, 06:43 AM
krob725 krob725 is offline
Basic Trainee
krob725 is an Observer
Default charging troubleshooting
here is a good source of lights. also about half way through is a LED conversion kit.
http://www.saturnsurplus.com/lights/lights.htm
k
67 M725 84 GW
HTML code is On
Switch Assemblies? Snuffy Open Discussion 4 December 28th, 2008 06:32 PM
glove box switch 14fan Open Discussion 14 November 24th, 2008 05:39 AM
three lever switch ryanroo Stock Tech 3 March 20th, 2008 09:47 AM
3-lever switch tngreenmachine Stock Tech 11 October 29th, 2007 08:58 AM
Ignition switch Roger1952 Stock Tech 4 March 18th, 2007 04:10 PM
