Old May 10th, 2004, 10:49 AM
kalikraven kalikraven is offline
kalikraven is a Soldier
If so please describe the setup as I am considering this option, my long term goal is a diesel but it may be awhile as I have 2 spare engines.
Old May 10th, 2004, 01:10 PM
Nuke_mcinfantry Nuke_mcinfantry is offline
Nuke_mcinfantry is an Observer
1998 gm master cyl (i think) disc.disc
1996 gm hydroboost
1967 M-715 (A1)
www.homepage.mac.com/ltalessi
Old May 10th, 2004, 08:26 PM
WetCJ's Avatar
WetCJ WetCJ is offline
WetCJ is a Soldier
Check the pictures of Joe/IA's truck in the members gallery (Brute4c's people, places+things) booster I believe is off a 80's diesel pickup. Probably some additional mounting holes and linkage customizing but the original pedal was used. Just add a return hose port to your steering pump(if you already have power steering) or possibly tee into original return line. This truck has been set up this way since 92.
Old May 10th, 2004, 08:29 PM
oops, i used stock pedal,stock rod (cut down a little though) and a jeep wagoneer firewall spacer
1967 M-715 (A1)
HTML code is On
Help me measure this to set up your hydroboost better... Elliott Modified Tech 8 February 28th, 2010 09:03 PM
hydroboost brakes foodstamp Modified Tech 4 December 25th, 2007 02:30 PM
Hydroboost Plumbing Barrman Modified Tech 14 May 17th, 2007 11:51 AM
