Page 12 of 18 FirstFirst ... 23456789101112131415161718 LastLast
Results 111 to 120 of 175
Thread: M715 Finland
  1. #111
    I have that smaller box (lower) I thought it was only turnsignal?
    3. Goes back to the lights. The driver-side front mudguard of such a fuse. I thought the 1st would go for it? For the headlights, the wires are ok
  2. #112
    Feb 2004
    Silver Lake Sand Dunes MI
    I agree with Brute, 1 looks like the wires for the horn and 3 is the harness splice to the rear of the vehicle. 2 is hard to tell from that pic but may be the blackout light wires.
    Dave
  3. #113
    Nothing now supplies electricity to the taillights. This is easy to the other side of the globe
  4. #114
    Feb 2004
    This diagram from Ron will be a big help for you to use to follow where each wire goes. The numbers stamped on the metal tags will match the numbers on this diagram. http://www.m715zone.com/vb/pages/man...solidstate.pdf
    In that pic that looks like a ballast resistor and is not stock on the M715.
    Dave
  5. #115
    does not have any fuses?
  6. #116
    Feb 2004
    Quote Originally Posted by M715Fin View Post
    Nope there are no fuses in a M715 like in a civilian vehicle. The light switch has an automatic resetting breaker in the event of a short.
    Dave
  7. #117
    Ok. Thanks
  8. #118
    Resolved so far.
    SER DRIVE = Headlights on
    SER DRIVE + PARK = park lights only
    B.O. MARKER = blackout marker lights on
    B.O. DRIVE = blackout light (hood)
    Is my wiring and light switch connections correctly so far?
  9. #119
    Hopefully this page helps you understand the 3 lever light switch and what works when:
    http://www.m715zone.com/vb/view.php?pg=20chap2-17
    And here is a wire diagragm I made of the cannon plug on the back of the 3 lever light switch and where each wire goes:
    http://www.m715zone.com/vb/pages/man...cannonplug.jpg
    There are more wire diagrams at the following link, including the one above, that document every wire in the stock early style harness:
    http://www.m715zone.com/vb/view.php?pg=early_harness
    Hope that helps...ask more if you need more though...glad to help!
  10. #120
    The garage starts to be tight.
    Finally I got more olive paint. Headlights all in place and connected Tail lights repaired and ready to install.
