Results 1 to 8 of 8
Thread: Serial Number location
    Default Serial Number location
    Is the serial numbers that match the plate number on the dash stamped into the frame. If so what is the location of these numbers. Thanks for all the help.
    I believe that should be stamped on top of the frame in over the passenger side of the rear axle and on top of the frame on the passenger side in the engine compartment right near the radiator support.
    -What We Have, We Hold-
    Springdale, Arkansas
    Just finished sandblasting and painting my frame yesterday and yes, thats exactly where I found them. They were lightly stamped and I had to look hard to find them but they were there. Kinda near the upper shock mount on the pass. side rear, on top.
    Heres an image to assist you:
    Default thanks for all the info
    thank you for the info i'm still looking and may have to sand a bit. thanks.
    Port Orchard, Wash.
    Use a fine sandpaper, blow it clean, then rub the area(s) with white chalk, then wipe. It might help make the lightly-stamped numbers stand out a bit.
    -- Tim Taylor
    I used a brass bristled brush a little bigger than a toothbrush and some gasoline.
    Jan 2007
    Fort Smith, Arkansas
    They are VERY lightly stamped on mine. Even after I found them in the rear (never found in front) I couldn't read all of the numbers. A little red paint and then resanding got them more visible.
  1. Frame rail serial number stamping locations
    By Binford in forum Stock Tech
    Last Post: June 4th, 2013, 06:35 PM
  2. engine serial numbers
    By jpsnblood in forum Stock Tech
    Last Post: May 3rd, 2009, 11:45 PM
  3. Vehicle Serial Number Locations
    By rboltz in forum Stock Tech
    Last Post: August 5th, 2008, 06:09 PM
  4. Frame Serial Number Location
    By metexaco in forum Open Discussion
    Last Post: June 25th, 2007, 10:27 PM
  5. Vehicle Serial Number
    By Joel in forum Stock Tech Archives
    Last Post: January 12th, 2004, 08:00 AM
