Results 1 to 2 of 2
Thread: Fuel Sender Ohms
    Nov 2008
    gulfport florida
    Default Fuel Sender Ohms
    Can't find the Ohms range for the stock fuel sender in any manuels. Anyone know the answer?
    Yes. It is 0-33 ohms.
    I forget if it is 33 at full or empty...I have posted it in the past...
    There is an older, like pre 66, GM car fuel sender that has a 0-33 ohm scale as well EXCEPT the scale the car uses is backwards of ours...so if that sender was used in our truck, it would read full when the truck was empty and empty when the truck was full.
  1. Fuel guage and sender install
    By randyscycle in forum Modified Tech
    Last Post: March 29th, 2013, 11:40 AM
  2. military fuel sender replacement
    By Snuffy in forum Modified Tech
    Last Post: April 9th, 2009, 12:51 PM
  3. 12 v fuel sender and guage
    Last Post: August 8th, 2008, 12:42 PM
  4. Fuel sender resistance
    Last Post: March 18th, 2008, 10:56 PM
  5. Fuel Gauge Sender
    By Barrman in forum Modified Tech Archives
    Last Post: February 12th, 2004, 01:31 PM
