Results 1 to 9 of 9
Thread: sermis : 350 exhaust
    Default sermis : 350 exhaust
    350 exhaust
    Post by sermis on Jun 19, 2006, 8:13am
    For those running a 350 and ram's horns. How did you route your exhaust running duel exhaust? I ran one pipe in the stock location and the other kinda in the same place on drivers side, however it gets really, really hot. So hot it melted the sole on my wife's shoe the other day. She's not a happy camper.
    Jan 2007
    Fort Smith, Arkansas
    Default wrecker :
    Re: 350 exhaust
    Post by wrecker on Jun 19, 2006, 8:52am
    I have this setup and for now, it exits to the outside of the frame rails between the leaf spring and the frame towards the rear shackle. There it runs a short distance to glass packs and then exits to the sides of the truck right behind the cab corners. I don't like this just because it doesn't look quite right where it crosses the frame. It does work however. I think Poolmike and Spicer both cut holes in the crossmember so as to allow the pipes to go through. Bill
    Mar 2004
    northern Arizona
    Default compexp :
    Re: 350 exhaust
    Post by compexp on Jun 19, 2006, 9:04am
    Sermis, on my 725, I routed outside the frame rail just behind the front springs and dump out in front of the rear tires.
    It still gets warm on the floor. I may look at floor liner or dynamat.
    Default barrman :
    Re: 350 exhaust
    Post by barrman on Jun 20, 2006, 9:49am
    Outside the frame or cut the cross member and cross over under the short shaft are the only two ways I have seen it.
    Default fasteddie :
    Re: 350 exhaust
    Post by fasteddie on Jun 23, 2006, 8:23pm
    On a 725 , with small block Chevy . Used ram horn manifolds , had the exhaust bent for truck . One pipe runs under passenger side and the other under the drivers side . Left side pipe takes a turn to the right just behind transfer case , then both run to a dual inlet & outlet flowmaster .After that they split to left & right to exit behind the tires . Except for the exits everything runs inside the frame rails . As for heat transfer , Dynamat worked good , also on top of the mat , I installed a jute pad then a rubber mat over that . Also installed the Dynamat on the insides of the door panels , seemed to help with noise control .
    Mar 2004
    northern Arizona
    Default compexp :
    Re: 350 exhaust
    Post by compexp on Jun 23, 2006, 9:03pm
    thanks eddie - looking at something like that for mine.
    Default whydah :
    Re: 350 exhaust
    Post by whydah on Jun 24, 2006, 2:22am
    tubes come down from my block huggers and join on drivers side. then, pass through torched hole in crossmember. somewhat straight back, exit behind rear fender. muffler is where the gas tank was.
    Default tacomainoh :
    Re: 350 exhaust
    Post by tacomainoh on Jun 24, 2006, 2:30am
    *gasp* whhhhhhhhaaaat? you're not running duals??????
    funny, I was just arguing strenuously for single exhaust, and there's your post.
    My 725 had pipes along the rails, exiting in front of the rear tires. VERY HOT! but the driver's side had insulation, and it was ok. Pass. side melted tape cases to the floor. Underbody heatshield would probably help. Learn from OEM's, they spend money on that stuff.
    Default whydah :
    Re: 350 exhaust
    Post by whydah on Jun 24, 2006, 2:31am
    yeah, i was going to do that. i have single 3" with single flowmaster. bending is not the best but it work for now. sounds perfect.
  1. sermis : Locker install
    By sermis in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 08:12 PM
  2. sermis : Motor swap
    By sermis in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 03:09 AM
  3. sermis : Duce Winch
    Last Post: November 11th, 2009, 12:30 AM
  4. sermis : Power steering mount
    Last Post: November 10th, 2009, 11:31 PM
  5. sermis : Accelerator peddle & cable
    Last Post: November 10th, 2009, 11:25 PM
