Results 1 to 10 of 10
Thread: spring over
    : i want to do a spring over on my truck, but want to get a good idea on what will need to be changed (drive shafts, relocated tie rod, ect..) before i jump into it. i want the truck to be completed as fast as posible it is my daily driver. any info would be great.
  2. Default
    this page has alot of great stuff. Check it out.
    http://homepage.mac.com/m715/jeep/index.html
    1969 M715
    thanks, that site had a lot of information but i want to use the stock front axle, dana 60's are very $$$$.$$ at the time. my biggest question i have is what to do with the tie rod, it looks like it will have to be rised. do the stock axles use the same steering arm lift blocks as a standard 60 ???
    Mar 2004
    Atlanta, GA
    Default gas tank
    When I did a spring over i my truck, I removed the tie rod and turned it over so that it comes in from the top side of the steering arms. I reamed the top side of the holes in the steering arms and filed them out to fit the tapered tie rod ends. I welded a bead around the hole on the lower side of the steering arms and re-drilled it to the size of the threads of the tie rod ends so that everything fit tight. I have also seen where the steering arms have been cut off, turned over and re-welded.
    I had to lenghten the drag link by 3 1/2 inches to compensate for the spring-over lift; however I did drive my truck for a long time by just adjusting the drag link out as far as it would go. It just turned sharper one way than it did the other.
    Jeremy
    thanks for the info. do they sell spacers to raise the streering arms, or is this my only option... if they dont make the spacers has any one made there own?
    You dont need spacers...just do the reaming as Jeremy described and put the springs on top with the longer drag link and you'll pick up 5 1/2 to 6 inches in the front.
    i will get on it. thanks
    They can't easily space the arm up as it houses the upper king pin.
    Big Blocks RULE!
    sorry if i sound retarded but have never had a dana 60 in a truck and dont know much about them internally, i just dont want to half ass anything on my truck
    M715,s..are a mans jeep...
    Lot's of stuff is different from brand to brand...don't sweat it. Always ask...don't assume. Good luck on the weekend spring over project!
    Big Blocks RULE!
  1. spring over conversion
    By talulah in forum Modified Tech
    Last Post: August 26th, 2014, 04:46 AM
  2. Spring bushings?
    Last Post: February 12th, 2009, 11:43 AM
  3. Ready for Spring
    By vrod02 in forum Open Discussion
    Last Post: March 9th, 2008, 08:47 AM
  4. Spring rates
    By bump_r in forum Open Discussion Archives
    Last Post: January 10th, 2004, 06:56 PM
