  #1
Old October 11th, 2017, 05:49 PM
Schoolbd Schoolbd is offline
New Recruit
Schoolbd is a Soldier
Default Transmission driveshaft
Would like to know if there are different type driveshafts from the trans to the transfercase short fixed type or slip yolk type
  #2
Old October 12th, 2017, 04:35 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Quote:
If you are talking the little short drive shaft, I have only seen one type, fixed length with universal joints. No slip yoke. For instance, the front and rear have slip joints because the differentials are moving up and down with the terrain.
  #3
Old October 12th, 2017, 06:49 AM
New Recruit
Don
I am speaking of the short shaft around 8", I'm installing a running engine from a 725 into my 715 the 715 had the short fixed type and the 725 has the slip yoke type , I assume it will be ok as it came from a running driveable truck, tried to post a pic of the two but couldn't
Regards
Herb
  #4
Old October 12th, 2017, 07:34 AM
venominjected's Avatar
venominjected venominjected is offline
Corporal
venominjected is a Soldier
I don't think it would matter... and a slip shaft would probably be the prefered one to be honest (even though its not what the OEM 715 had)
__________________
1967 M715, 6BT, ZFS542, NP205
  #5
Old October 12th, 2017, 01:41 PM
osut362's Avatar
osut362 osut362 is offline
Private 1st Class
osut362 is a Soldier
check out this very old post I made when I still had black hair. It may help, may not. http://m715zone.com/vb/showthread.ph...highlight=slip
  #6
Old October 12th, 2017, 06:44 PM
New Recruit
The 725 this slip yoke came from was totally stock hard to believe it's not original to the truck
  #7
Old October 13th, 2017, 08:11 AM
brycer1968's Avatar
brycer1968 brycer1968 is offline
Private
brycer1968 is a Soldier
Default M725 slip joint
I did a ton of research to make up a very short slip joint shaft out of Spicer parts for my SBC 350/SM465 to stock NP200. It wasn't cheap, but it works great and if picture posting were easy/possible on here, I'd post a pic of it on here.
Bryce
__________________
1969 M725 ambulance
  #8
Old October 14th, 2017, 06:45 PM
New Recruit
Going to install my engine and trans with slip yoke this coming week , will be glad to have it running , thanks for the replies
  #9
Old October 14th, 2017, 10:27 PM
tomb's Avatar
tomb tomb is offline
Private
tomb is a Soldier
this is the shortest slip shaft I have ever made.
m715 066 by tom boyer, on Flickr
  #10
Old October 15th, 2017, 05:56 AM
New Recruit
Mine looks identical, just a little longer, thanks for the photo
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
