Go Back   M715 Zone > General Tech > Modified Tech > Modified Tech Archives
  #1
Old May 21st, 2004, 10:56 AM
Joel Joel is offline
Private
Joel is an Observer
I picked up a stock carb mounted air cleaner and tried to fit it on a civvie carb. It didn't work because the carb is too short. I want to run the stock the stock air cleaner so I can hook up the vent lines from the brakes, block etc.
Has anyone done the same thing and if so how did they do it (spacer under carb or between carb and air cleaner)? Otherwise what did you do for the vent lines if you ran a different air cleaner.
  #2
Old May 21st, 2004, 11:01 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
I use an aftermarket one but it had little knockout holes and fittings to go in them...so I hooked the hoses together and ran them to the 2 ports on the new air cleaner.....
For yours, if the stock can will mount on the air cleaner neck.....I would use a spacer under the carb....wont hurt a thing...might help actually.....but slightly in power terms....
__________________
  #3
Old May 21st, 2004, 11:10 AM
Private
Joel is an Observer
My first choice would be a spacer of some sort. May be add a gutted govener to get the height.
Would it be worth it to get a stock carb and put it back on the truck instead, or is the civvie carb better?
  #4
Old May 21st, 2004, 11:13 AM
brute4c's Avatar
Grand Poobah
You running a 1920 Holley or something different....the mil one is the 1920.....
Spacer would be my choice for sure....gona need longer studs maybe.....
__________________
  #5
Old May 21st, 2004, 11:18 AM
Private
Joel is an Observer
I don't remember the model number of the top of my head, but if I remember correct it says 1920 or 1930. From looking at other pics and the manuals besides being shorter the only other visible difference is the fuel inlet comes out the side not the front like the Military 1920 Hollie.
  #6
Old May 21st, 2004, 04:23 PM
Nuke_Danarchy Nuke_Danarchy is offline
Private
Nuke_Danarchy is an Observer
On my1969 I started with the Giant CanisterAir-Filter contraption and wanted to use the old original style air-filter housing. I used a spacer and it worked o.k., but the clearence between the hood and the air-filter was very close. I am now scraping that Idea and going to a civilian 2-barrel and tap the hoses in like Brute mentioned. I have a couple of spacers if you need.
__________________
1969 M715
  #7
Old May 22nd, 2004, 08:07 AM
brute4c's Avatar
Grand Poobah
The civvie and military 230's do have a different fuel location...front vs side....other than that and the accelerator pump lever which is better on the civvy, metal, vs the mil, plastic, they are the same.
Either would work as good as the other.
__________________
  #8
Old May 24th, 2004, 08:01 AM
Private
Joel is an Observer
Danarchy
I am going home tonight to measure how much I will need. If you have a spacer that you can part with it would be easier than me making one and I would appreciate it.
HTML code is On
Stock carb kit info SHOOTER68 Stock Tech 87 June 3rd, 2018 10:35 AM
Air Cleaner for 2 Barrel Carb rboltz Modified Tech 16 February 5th, 2017 11:47 PM
Alternative for stock carb and air cleaner Snookie Stock Tech 3 December 30th, 2010 12:45 PM
What carb is stock ? ? Tom @ Snake River Stock Tech 6 May 2nd, 2009 07:51 PM
1998 - 2020
Copyright 1998-2020
