  #21
Old November 17th, 2010, 09:36 PM
Binford's Avatar
Binford Binford is offline
Moderator
Binford is a Soldier
I believe the technical manuals call out the location of the serial number stamps, don't they, brute? You could show the inspector the manual (or this thread, for that matter) for assurance that your number stamp is legit.
-- Tim Taylor
  #22
Old May 18th, 2011, 12:29 PM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Here is something interesting.
I can't look at the rear frame rail because a 5th wheel setup is welded to the frame there. (Holes cut in the bed for the mounting) I sanded the front location of the frame and it is totally clean. No numbers or evidence whatsoever of stampings:
The Title lists the number 10467.
The dash has a button for a Mico Type brake hold. There is a solenoid in the rear brake line near the gas tank (which will be removed).
There is a data plate for the "Welder"
There was some kind of mechanical governor (that I removed) that had a speedometer type cable that went to the rear of the vehicle but not connected in the rear. There was a connection from the governor to the carburetor linkage.
There was no data plate on the dash board with the rest of the data plates.
So, what is it, M726 with an M715 bed on it?
  #23
Old May 18th, 2011, 12:40 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Sure does seem to be adding up to that. Better watch the auction in FL so you can get a bed to match your truck.
  #24
Old May 18th, 2011, 12:48 PM
Don Cavey's Avatar
Staff Sergeant
Quote:
That would be nice. But I am not in a position to do that right now. For that matter, where I am moving to will be a neighborhood that does NOT allow any vehicles sitting around. I will be keeping the M715 in the garage because I don't want the canvas to get wet and I am sure some of the neighbors would be "offended". It is a golf course community. No, I don't golf but the house was a steal and I just couldn't resist.
  #25
Old May 18th, 2011, 01:21 PM
Don Cavey's Avatar
Staff Sergeant
Here are the plates on the dash. Certainly was not originally an M715. And since the title is for 1969, the serial number (10467) doesn't fit in with the M715 series for the year 1969, more like 4/67?
Here is the massive frame attachment for the 5th wheel on the top of the frame:
And an attempt to show you the front frame. What appears to be a number is actually some welding spatter.
  #26
Old May 18th, 2011, 01:27 PM
Barrman's Avatar
Chief 9-flats
Do you for sure have a NP200 tcase or maybe the 205?
  #27
Old May 18th, 2011, 01:31 PM
Don Cavey's Avatar
Staff Sergeant
Don't know the difference. Is there something that makes it obvious... something that is different? It does have the winch lever in the correct location even though my truck has a duce and half winch
  #28
Old May 18th, 2011, 01:34 PM
Barrman's Avatar
Chief 9-flats
NP205 has a pto port on the drivers side. NP200 has no pto port.
NP205 has the rear drive shaft output in line with the input from the transmission. NP200 has two rear outputs with the drive shaft supposed to be on the passenger side and not on the brake output.
  #29
Old May 18th, 2011, 01:45 PM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
You have a M724. You should also have a slot on the drivers side of the tranny tunnel where the rear axle disconnect for the welder/generator was connected.
Interestingly, your serial number would be the highest registered M724 serial number in the registry.
  #30
Old May 18th, 2011, 01:50 PM
kwai's Avatar
Sergeant
kwai is a Soldier
The M724 had the gas tank in the rear between the frame rails (where the spare goes on the M715). I assume your gas tank was located in the usual M715 location?
Tags
serial number, vin, vin number
Vehicle Serial Number Locations rboltz Stock Tech 9 August 5th, 2008 03:09 PM
Frame Serial Number Location metexaco Open Discussion 4 June 25th, 2007 07:27 PM
Serial Number location blueridgekaiser Stock Tech 7 February 8th, 2007 08:45 AM
Vehicle Serial Number Joel Stock Tech Archives 2 January 12th, 2004 05:00 AM
