  #31
Old May 18th, 2011, 02:03 PM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Quote:
Originally Posted by kwai View Post
The M724 had the gas tank in the rear between the frame rails (where the spare goes on the M715). I assume your gas tank was located in the usual M715 location?
Tank was a conventional M715 type. But I can tell it had been down. And no ground wire on the sending unit. Shouldn't there be one?
  #32
Old May 18th, 2011, 02:04 PM
Don Cavey's Avatar
Staff Sergeant
You have a M724. You should also have a slot on the drivers side of the tranny tunnel where the rear axle disconnect for the welder/generator was connected.
Interestingly, your serial number would be the highest registered M724 serial number in the registry.
There is a plate albeit home made on the tunnel. I will post a picture...
  #33
Old March 8th, 2012, 06:59 PM
alosix alosix is offline
alosix is a Soldier
Thanks for this. Helped me a lot today with the VIN inspector getting mine ready to get tags.
Couldn't find the front one (POR-15 + some grinding when we redid the front end).
The rear one was found with just a bit of wire wheeling right over the rear axle on the M725.
Thanks.. saved the day for the most part.
  #34
Old May 29th, 2013, 03:28 PM
DansM715 DansM715 is offline
DansM715 is a Soldier
Quote:
Originally Posted by Binford View Post
I believe the technical manuals call out the location of the serial number stamps, don't they, brute? You could show the inspector the manual (or this thread, for that matter) for assurance that your number stamp is legit.
Can you tell me which manual has this info? We have looked through the following manuals and are unable to find it:
TM 9-2320-244-20
TM 9-2320-244-20P
TM 9-2320-244-34
  #35
Old May 30th, 2013, 04:13 AM
Don Cavey's Avatar
Staff Sergeant
Does this answer it or did you already find the info? Not sure if you want to actually see in writing in the TMs...
Frame rail serial number stamping locations
  #36
Old May 30th, 2013, 08:26 AM
Sorry I wasn`t real clear. I`d like to show a inspector a manual that refers to the serial number stamp, as I am trying to get a title for a m715 with no data plate.
  #37
Old May 30th, 2013, 08:55 AM
Oops, ment m725.
  #38
Old June 3rd, 2013, 04:49 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
This thread was started because there is no manual to view this information in...
  #39
Old June 4th, 2013, 03:35 PM
Thank you, brute4c.
Tags
serial number, vin, vin number
Vehicle Serial Number Locations rboltz Stock Tech 9 August 5th, 2008 03:09 PM
Frame Serial Number Location metexaco Open Discussion 4 June 25th, 2007 07:27 PM
Serial Number location blueridgekaiser Stock Tech 7 February 8th, 2007 08:45 AM
Vehicle Serial Number Joel Stock Tech Archives 2 January 12th, 2004 05:00 AM
