  #11
Old April 7th, 2009, 08:31 PM
67M715's Avatar
67M715 67M715 is offline
Private 1st Class
67M715 is a Soldier
Here is the whole shaft installed. Sorry about all of the hydroboost and brake hoses in the way but you get the picture:
Close up of the vibration reducer u-joint that is on the steering box end of the shaft:
Close up of the u-joint on the column end, this is where I ground down the factory steering shaft (after cutting off the bottom 'T' piece) to a 3/4 DD:
1967 M715 w/ 454 and TH400
  #12
Old April 7th, 2009, 08:33 PM
67M715's Avatar
Private 1st Class
67M715 is a Soldier
These next 3 pictures show the end of the column and how it looks after being modified:
Here is the shaft completely out of the truck:
  #13
Old April 7th, 2009, 08:36 PM
67M715's Avatar
Private 1st Class
67M715 is a Soldier
One other safety factor on this is that the shaft is now collapsible, which is important if the truck was ever in a front end collision, the steering wheel wouldn't come shooting at me, the shaft would collapse 4-5 inches and hopefully lessen injury.
  #14
Old April 7th, 2009, 08:45 PM
67M715's Avatar
Private 1st Class
67M715 is a Soldier
Quote:
Originally Posted by Jester View Post
Here is my guess on parts from Borgeson - please correct me if I am off base.
shaft - 450024 - telescoping shaft, 21-27 inch, 3/4" DD & 1" DD
box u-joint - 014940 - 3/4" DD & 13/16" x 36 spline
column u-joint - 014952 - 1" DD & 3/4" DD
The column shaft would have to be ground to 3/4" DD.
These are priced around $225 from Summit. Sure Brent would be cheaper
Would love to see pics.
Those part numbers look correct to me, I couldn't find my factory steering box to double check (I have a power steering box from a 85ish Grand Wagoneer which is 3/4-30 spline).
The only issue I see with your setup is you are running a ujoint on the box and on the column. Since the rag joint has been eliminated, the vibration reducer that I put on is meant to replace that, if you don't you will get a lot more road vibrations up to the steering wheel and as we ALL know, these M715's are already not the easiest or the most comfortable to drive so every little bit helps.
Looks like with the shaft (cut to the correct length), the vibration reducer at the box and the ujoint to the column we could do a kit for about $260 or so, if there is enough interest I will set up a page on the webstore.
  #15
Old April 7th, 2009, 08:56 PM
Jester
Guest
Posts: n/a
OK, so how much and when can we order?
  #16
Old April 8th, 2009, 06:50 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
I gotta say it....
That is absolutely beautiful!!
  #17
Old April 8th, 2009, 08:18 AM
Jester
Guest
Posts: n/a
Quote:
I was guessing on my listing. I can double check my power steering box and the manual one in the junk pile.
True. I was being cheap but the vibration reducer would be a big help.
I am interested. Isn't that enough? Since I have already tossed all the rag joint and tulip thingy, I gotta do it. Its just a matter of where in the process and what parts.
BTW - did you go with steel or bling all out with stainless?
  #18
Old April 8th, 2009, 09:11 AM
NickS NickS is offline
New Recruit
NickS is a Soldier
Default Great looking part
I'll take one too.
Nick
  #19
Old October 16th, 2012, 09:27 AM
97XJSP's Avatar
97XJSP 97XJSP is offline
Private 1st Class
97XJSP is a Soldier
Digging this one back up!
I just ended up ordering the exact same parts for my swap. Seems like the best way to do it. Certainly not the most cost effective, but I think it'll work out real nice. I almost saved the $35 and didn't get a vibration dampener joint, but I figured since I'm rebuilding everything else it would be worth it. If someone else wants to do something similar but for less money, there is a much less expensive way. I used a jeep YJ saginaw "76" box and it came with the stock steering shaft. The stock shaft is just like this one, 3/4"DD x 1"DD but the upper joint is meant for a 1" shaft, while the 715 is a 3/4" shaft. Conceivably, you could use the YJ shaft and just buy a single new upper joint (1"DD x 3/4"DD) to connect the YJ shaft to the 715 column shaft. For some reason the YJ uses the vibration dampener at the top of the shaft, so you'd have to buy one of those if you wanted to have one. My YJ shaft was trashed, so I didn't consider it but I think it would still be a good option. The YJ shaft would also have to be trimmed a couple inches, but that's easy. There are plenty of vehicles that use that shaft, so you could always find a decent one at the junkyard to save a few bucks and buy new joints for it too... Here is the list of parts I ordered (the YJ box is 3/4"x30 spline). I also ordered a Grant wheel and adapter, for a little more leg room.
Part Number Part Description Price
BRG-014952 U JOINT $75.72
BRG-034931 U-JOINT $110.24
BRG-450024 24" TELESCOPIC SHAFT $74.97
GRT-414 STEERING WHEEL 13 1/2 BLK $49.95
GRT-4403 INSTALLATION KIT $22.95
  #20
Old July 23rd, 2019, 09:58 AM
roadglide roadglide is offline
New Recruit
roadglide is a Soldier
Default Steering shaft 69 M715
What would be the size shaft and spline of the upper shaft in the steering column.
I am also looking to do a conversion .
Possible to save lower rag joint but using upper u-joint.
If this will not work, need part numbers on 2-u-joints (upper and lower) and part # on DD shaft. (Bourgeson)
Thanks.
calpyro : NP205 to 3053A trans adapter and bell housing PseudoZone PseudoZone - Open Archive 8 November 11th, 2009 12:18 AM
Deuce trans / Chev Bell sermis Modified Tech 16 December 26th, 2007 06:52 PM
steering box angler Open Discussion 2 June 3rd, 2007 03:16 PM
Stock specs for stock axle, wheel, brake drums & tires brute4c Stock Tech Archives 0 May 31st, 2007 06:46 AM
Power Steering w/stock 230 Fastfrankie Open Discussion 8 January 9th, 2007 08:43 AM
