Go Back   M715 Zone > General Tech > Stock Tech > PseudoZone - Stock Tech Archive
Old December 15th, 2009, 12:05 PM
Moderator
PseudoZone is a Soldier
Default fwdstuck : clutch problems??
clutch problems??
Post by fwdstuck on Oct 14, 2006, 11:05am
My clutch on my truck is stuck. When I bought it, it was working fine. Like a brand new clutch. Then one day I started it up. And the clutch won't engauge. I took the plate off and looked at it.
Everything looks good. Is it stuck to the flywheel or the pressure
plate? If anyone has any info let me know. Thanks
Moderator
Default fwdstuck :
Re: clutch problems??
Post by fwdstuck on Oct 14, 2006, 2:07pm
I finally got it broke loose. I had it in the river right before it done this. That might be the cause. I just took a piece of pipe to hold the clutch down. Put it in gear. And jack up one of the rear wheels. And kelp poping it untill it broke loose. I spayed the clutch disc with wd-40 while I was turning the wheel with my foot.
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
Default mikel :
Post by mikel on Oct 14, 2006, 3:58pm
Next time your clutch sticks, pop the tranny into 4th gear, step on the brakes and start the engine
I bought an 89 Mustang for $300 years ago. I got a call from the buyer, saying that the clutch had died and the car couldn't be driven, if I towed the car away that day, I could have it for $300. I freed up the clutch and drove away for $300
HTML code is On
fwdstuck : one plug wire, low spark PseudoZone PseudoZone - Open Archive 4 November 10th, 2009 11:24 PM
fwdstuck : rebuilding fuel pump problem PseudoZone PseudoZone - Open Archive 2 November 10th, 2009 09:29 PM
V8 problems scottsmyth Modified Tech 7 June 22nd, 2009 09:04 PM
pulling out problems when releasing clutch randall555 Stock Tech 2 February 10th, 2009 05:58 PM
