Results 1 to 7 of 7
Thread: koobster : timing chain copper links?
    Default koobster : timing chain copper links?
    Post by koobster on Oct 22, 2006, 5:02am
    I am ready to put on the head, looking at the timming chain there is not any copper links. Any segestions?
    Default brute4c :
    Re: timing chain copper links?
    Post by brute4c on Oct 22, 2006, 8:14am
    Look on the other side?
    I know, that wasnt funny...
    All the stuff I have, military and civilian, talk about the copper links....
    Getting a different chain is all I can think...sorry to say...
    Default jfnemt1ff1 :
    Post by jfnemt1ff1 on Oct 22, 2006, 8:15am
    I good be wrong but I think the copper links only help in finding the dots on the gears. Thats the way it s on other cars. Just make sure the dots are in the right spots,the chain should not make a diffrent.
    John
    SF Bay Area, CA
    Default hiker :
    Post by hiker on Oct 22, 2006, 1:13pm
    The chains don't seem to have the copper links anymore. A suggestion would be to count the links and temporarely mark your chain for reference. I don't know the count off hand is it 32links guys? Just confirm that the #1 cam lobe is pointed straight down 6:00 position with piston on TDC of the compression stroke.
    SF Bay Area, CA
    Default hiker :
    Post by hiker on Oct 22, 2006, 2:37pm
    From the -34 manual, Thanks again Brut4c for making them available:
    4) Position crankshaft timing chain sprocket and camshaft timing chain sprocket in opposite ends of timing chain so keyway of timing chain sprocket is up and
    the dowel of the camshaft sprocket is down. Position parts so copper links of the chain are aimed with timing marks on the sprockets. The copper segments are
    32 links apart. Refer to figure 3-12.
    Note that figure 3-12 is of no real help in viewing this.
    Here's a link to an Argentine web site that gives a rough picture of the timing chain set up. It's the 32 link set up (4 Bancadas = 4 [main] Bearings. Note that this picture is just to give you the general idea (it's incorrectly drawn with only 24 links)
    http://jeepgladiator.com.ar/mec/distr01.jpg
    Also confirm that the distributor rotor is pointed towards the #1 spark plug wire location, not the #6 position.
    Default koobster :
    Post by koobster on Oct 22, 2006, 7:27pm
    Thanks guys. After cleaning the chain a little better i found two links that are not a dark as the rest, and 32 links apart, I used those.
    Default brute4c :
    Post by brute4c on Oct 23, 2006, 5:44pm
    Probably the ones you needed!!
    The problem with lining up he timing marks on the grears like you do with other stuff is that there is no mark on the cam gear...you point it down with the #1 cam lobe...points straight down as ha been mentioned above...
    The crank gear has a mark that the chain lines up to on the drivers side of the gear, straight across from the mark to the link...that should put the upper copper link right at the bottom of the cam gear...but no mark there to reference...
    Its an oddball...especially in this area...
  1. koobster : a few quiks of the a-1
    Last Post: November 12th, 2009, 05:06 AM
  2. Are all these copper plated?
    By rboltz in forum Stock Tech
    Last Post: May 1st, 2008, 10:25 AM
  3. timing chain and gear marks
    By Sparky in forum Stock Tech
    Last Post: July 16th, 2007, 01:30 PM
