Go Back   M715 Zone > General Tech > Stock Tech > PseudoZone - Stock Tech Archive
Old December 15th, 2009, 12:14 PM
vrod02 vrod02 is offline
Private 1st Class
vrod02 is a Soldier
Default vrod02 : 230 "Lite" rebuild kit?
Post by vrod02 on Nov 14, 2006, 1:26pm
Thinking of a light motor in overhaul, Carbon cleanup,valve guides,hone and rings.IF I can find the parts! Anybody know where to find em?
fisherman's Avatar
Sergeant
fisherman is a Soldier
Default fisherman :
Re: 230 "Lite" rebuild kit?
Post by fisherman on Nov 14, 2006, 3:15pm
You don't even want to know what it will cost you. Look the other way and run. Do a conversion much cheaper. Trust me I spent over 3 grand on the turd of an engine was going to do the 2 barrel conversion and had the civilian distributor and everything. I drove it less than 20 hours and pulled it out. Working on finishing my v-8 truck.
Private 1st Class
vrod02 is a Soldier
Default vrod02 :
Post by vrod02 on Nov 14, 2006, 3:43pm
Found these guys.Some cheap, others out of site.
Lite was the key word, no bearings,rods or pistons.Gaskets can be made,other than a head gasket.. Just need to find rings and valve guides. Times money.Even the full kit is cheaper than a conversion IMHO. She runs fine just puffin more than I like.
http://www.kanter.com/wiln.html
HTML code is On
Mike's Restoration Thread, "The List", Current Progress... BubbaWilkins Open Discussion 21 January 27th, 2011 12:24 PM
Brake hose and throttle cable "clips" rboltz Stock Tech 2 December 5th, 2007 05:35 PM
