Go Back   M715 Zone > General Tech > Stock Tech > PseudoZone - Stock Tech Archive
Old December 15th, 2009, 12:16 PM
Moderator
PseudoZone is a Soldier
Default m725kid19 : stock tires?
stock tires?
Post by m725kid19 on Nov 16, 2006, 8:07pm
This may be a stupid question but I'm new with these trucks. What tires were stock for the m725's? I have Goodyear Xtragrips on mine and I'm pretty sure those aren't the original. I do have a tire that looks original mounted underneath, but i haven't had an opportunity to look at it.
gimpyrobb's Avatar
gimpyrobb gimpyrobb is offline
Sergeant
gimpyrobb is a Soldier
Default gimpyrobb :
Re: stock tires?
Post by gimpyrobb on Nov 16, 2006, 10:10pm
9x16 ndt?
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
Default k8icu :
Re: stock tires?
Post by k8icu on Nov 16, 2006, 10:14pm
900x16 nondirectional cross country (NDCC) tires. Standard military issue.
gimpyrobb's Avatar
Sergeant
Default gimpyrobb :
Re: stock tires?
Post by gimpyrobb on Nov 16, 2006, 10:47pm
Thats what I ment, thanks Joe!
hiker's Avatar
hiker hiker is offline
Corporal
hiker is a Soldier
Default hiker :
Re: stock tires?
Post by hiker on Nov 17, 2006, 2:15am
One source of the stock military tire is Wallace Wade. They run about $130 each. contact info
http://www.wallacewade.com
  #6
Moderator
Default m715guy :
Re: stock tires?
Post by m715guy on Nov 19, 2006, 11:28am
Hear is a websight that has the tires and tubes for sale. Plus other parts as well. www.surplusjeep.com. the tires are 175.00 a piece and the tubes are about 27.00
  #7
Moderator
Default m725kid19 :
Re: stock tires?
Post by m725kid19 on Nov 19, 2006, 3:40pm
are the Michelin xl's highly recommended? they are mentioned many times throughout the forums.
  #8
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default compexp :
Re: stock tires?
Post by compexp on Nov 19, 2006, 3:55pm
the stock NDTs have another nickname - No d**n Traction. They suck on the street and in serious mud. Plus, they are bias ply and don't ride well.
Most of us run 36 or 38" radials - I have Super Swampers and have had good luck. The XLs are 38" high, cheap as surplus, and do pretty well traction wise. I personally would prefer the XZLs, which are more of an all-terrain than the XLs, but they're harder to find.
  #9
Moderator
Default m725kid19 :
Re: stock tires?
Post by m725kid19 on Nov 19, 2006, 5:07pm
do the XL's fit on the stock rims or do i have to replace those?
also what size XL is the right one?
also do those fit without rubbing on a stock suspension set up?
  #10
Moderator
Default rpgdeity :
Re: stock tires?
Post by rpgdeity on Nov 19, 2006, 5:52pm
The 11r16 XLs fit on a 16 inch rim (stock rim is 16"), and are 38" diameter. These will fit without rubbing on a stock suspension. There are larger size XL's, but they have different rim sizes as well as being to large to fit with a stock suspension.
HTML code is On
Balancing stock tires/rims Fastfrankie Open Discussion 8 February 22nd, 2018 06:37 PM
Biggest Tires Stock Axles V8 HAWKEYE Open Discussion 10 February 1st, 2009 05:23 PM
? about stock rims and newer tires. SouthernM715 Stock Tech 6 October 28th, 2007 04:09 PM
Stock specs for stock axle, wheel, brake drums & tires brute4c Stock Tech Archives 0 May 31st, 2007 06:46 AM
Real Top Speed Limit On Stock Tires JB7YO Open Discussion 9 January 25th, 2007 03:30 PM
