  #11
Old December 15th, 2009, 05:06 PM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Default barrman :
Re: Radiator in the bed ??
Post by barrman on Nov 2, 2006, 9:59am
Here is the best picture I have of the fan here at work. It was taken over a year ago, but you get the idea.
  #12
Barrman's Avatar
Chief 9-flats
Default barrman :
Post by barrman on Nov 2, 2006, 10:00am
I still have enough room in front of the fan to use a short socket and a 3/8" ratchet drive to install the bolts.
  #13
Elohim1 Elohim1 is offline
Elohim1 is a Soldier
Default elohim1 :
Post by elohim1 on Nov 2, 2006, 6:52pm
Quote:
I've got a 454 and a tilt front- I fit a stock Ron Davis dual pass rad. with two puller fans- fabbed a custom mount. Pass. fan motor misses alt. by about 1/4 inch. Works great though. Gimme your e-mail and I'll sent pix if it helps. Won't be till next week though, I'm headed to Mex this weekend
Yes, please send pics of this tilt setup to : elohimfirst@msn.com
Chris
Good info. gents.
  #14
40Grit's Avatar
40Grit 40Grit is offline
Private 1st Class
40Grit is a Soldier
Default 40grit :
Post by 40grit on Nov 2, 2006, 8:27pm
sorry boss, got so friggen busy with DieHard4 filming today...I'm going in tomorrow to work on 715, i'll get them tomorrow...
  #15
40Grit's Avatar
Private 1st Class
40Grit is a Soldier
Default 40grit :
Post by 40grit on Nov 3, 2006, 4:53pm
ok, here's a bunch...
front view, ground level
[img=http://img292.imageshack.us/img292/5607/coresupport002qc6.th.jpg]
top view
[img=http://img126.imageshack.us/img126/7586/coresupport003ty0.th.jpg]
passenger side rear view
[img=http://img293.imageshack.us/img293/4955/coresupport004ht4.th.jpg]
driver side rear view
[img=http://img527.imageshack.us/img527/4599/coresupport005aw2.th.jpg]
yet another view
[img=http://img170.imageshack.us/img170/7326/coresupport006el6.th.jpg]
radiator I'm using, with Flexilite 292 monster fans ( 31x19 universal Gm rad)
[img=http://img527.imageshack.us/img527/2104/coresupportsc1.th.jpg]
no put together pics, but the rad fits in front, about 3" further forward than stock with the fans behind it...leaves about 1" to front of water pump serp pulley...still has room for auto tranny cooler in front if I decided to change down the road...
supports are made of steel framing member, cost $11 for 10' section, cut a few pieces out, bent some in half lengthwise and used them for front supports, with a thin strip of rubber, it fits perfect around tanks on radiator, just need to fab top and bottom brackets, and drill holes for fans to mount...
  #16
Default elohim1 :
Post by elohim1 on Nov 3, 2006, 9:29pm
Much appreciated 40grit !!!
HTML code is On
elohim1 : On board air with GM compressor ?? Elohim1 PseudoZone - Mod Tech Archive 13 December 15th, 2009 05:24 PM
elohim1 : BBC header selection, what did you use? Elohim1 PseudoZone - Mod Tech Archive 30 December 15th, 2009 04:48 PM
elohim1 : Serpentine system and ON board Air ?? Elohim1 PseudoZone - Open Archive 3 November 11th, 2009 11:29 PM
elohim1 : What is the spacing on the points for a 230? Elohim1 PseudoZone - Open Archive 4 November 11th, 2009 02:09 AM
elohim1 : Which 502 motor should I use? Elohim1 PseudoZone - Open Archive 11 November 11th, 2009 01:46 AM
