  #11
Old December 15th, 2009, 05:13 PM
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default compexp :
Re: FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE
Post by compexp on Oct 7, 2006, 2:17pm
so find those hubs, and they will bolt on to give us 8-lug one-piece rim compatibility?
If so, THANK YOU BOB!
  #12
Moderator
PseudoZone is a Soldier
Default robertcowan :
Post by robertcowan on Oct 7, 2006, 6:02pm
YEP
  #13
Moderator
Default stanman :
Post by stanman on Oct 7, 2006, 9:13pm
so this is a bolt on, no modification whatsoever?! COOL!
  #14
40Grit's Avatar
40Grit 40Grit is offline
Private 1st Class
40Grit is a Soldier
Default 40grit :
Post by 40grit on Oct 8, 2006, 12:51am
i thought there was something about the spindles being different...back on the old board...
  #15
Moderator
Post by robertcowan on Oct 8, 2006, 2:45pm
NOPE
  #16
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Post by brute4c on Oct 8, 2006, 2:57pm
I seem to remeber the same thing...but I wish I had the old board....dont we all...
  #17
wrecker's Avatar
wrecker wrecker is offline
Sergeant
wrecker is a Soldier
Default wrecker :
Post by wrecker on Oct 9, 2006, 10:33am
So are they or aren't they a bolt on?
  #18
40Grit's Avatar
Private 1st Class
40Grit is a Soldier
Default 40grit :
Post by 40grit on Oct 10, 2006, 1:30am
let me look at work tomorrow, I have more stuff saved there....
it thought you had to change out the spindle and machine a little to make it fit...
somehting about a difference of a 1/4 inch or somethign comes to mind...
  #19
BigWheelBob's Avatar
BigWheelBob BigWheelBob is offline
BigWheelBob is an Observer
Default bigwheelbob :
Post by bigwheelbob on Oct 10, 2006, 6:35am
I know I used to use the 14 bolt hubs on the front, and If I remember right, I had to make a 1/4 spacer for them. Been awhile though.
  #20
Moderator
Default tngreenmachine :
Post by tngreenmachine on Oct 10, 2006, 6:42pm
I would like to know if rear 60 hubs could be used for the 60 front. Those are pretty easy to find. I don't think I have ever actually seen a 60 front axle that old.. I would be interested in the 14 bolt conversion too even with a spacer seems like the way to go.
HTML code is On
front hubs? need info! dave Stock Tech 8 June 10th, 2008 03:14 PM
front lock out hubs dave Modified Tech 12 May 30th, 2008 06:12 PM
Moding m715 front axle 503m715 Modified Tech 9 April 29th, 2008 02:55 PM
How get into front Hubs and Pull rear Diff? HUMMER103 Modified Tech 10 February 6th, 2008 12:43 PM
m715 front axle heepofajeep Open Discussion Archives 16 May 24th, 2004 07:29 AM
