  #21
Old December 15th, 2009, 05:14 PM
Moderator
PseudoZone is a Soldier
Default alosix :
Re: FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE
Post by alosix on Nov 13, 2006, 6:29am
Bob,
Any update on this?
Thanks,
Jason
  #22
Moderator
Default robertcowan :
Post by robertcowan on Nov 13, 2006, 10:15am
i havent had time to do the rears but i got all to do it. its a simple swap with a small amount of machining. my machineist has had some medical trouble and is out of commission till early next year.
bob
  #23
Moderator
Default 12998 :
Post by 12998 on Nov 15, 2006, 9:24pm
So the 67 to 69 dodges and fords bolt directly on the rear without any modification? And the same year and make hubs work on the front with a little machining? I know your machinist is out of commission but can you give us a hint about what needs to be done. Now where do we find these monsters? How about brakes, what is the deal with them? Take them off the donor or is there some other option?
  #24
Moderator
Default tacomainoh :
Post by tacomainoh on Nov 15, 2006, 9:30pm
  #25
boghog's Avatar
boghog boghog is offline
Private 1st Class
boghog is a Soldier
Default boghog :
Post by boghog on Nov 16, 2006, 9:03am
Now, if this is done, this means that you also need the drums for the same year Dodge or Ford? Or are you guys switching to disc on the axles. I am guessing that this makes it easier to get brake parts, one piece rims?
HTML code is On
front hubs? need info! dave Stock Tech 8 June 10th, 2008 03:14 PM
front lock out hubs dave Modified Tech 12 May 30th, 2008 06:12 PM
Moding m715 front axle 503m715 Modified Tech 9 April 29th, 2008 02:55 PM
How get into front Hubs and Pull rear Diff? HUMMER103 Modified Tech 10 February 6th, 2008 12:43 PM
m715 front axle heepofajeep Open Discussion Archives 16 May 24th, 2004 07:29 AM
