Old December 15th, 2009, 05:16 PM
Moderator
PseudoZone is a Soldier
Default alosix : DS drop front axle?
DS drop front axle?
Post by alosix on Nov 21, 2006, 8:24am
Finally aquired the drivetrain for the M725. Wanted diesel, but didn't want to pay for it. Have a complete 5.7 Hemi/trans/t-case on the way now from a 2005 1500 pickup.
This means DS drop front end. I'm 1/2 tempted to put the 2nd gen dodge 5 link up front and use a D60/D70 combo out of one of those trucks.
Looking for any other suggestions. Would stay leaves if I can get the axle at a decent price.
Thanks,
Jason
Moderator
Default tacomainoh :
Re: DS drop front axle?
Post by tacomainoh on Nov 21, 2006, 11:06am
Uhmmmmm get a Dodge axle??? Ford???
Or see if an older Dodge 205 will fit on your trans. That's what I did w/the Cummins I'm putting in (again) my 87 Chevy.
Old December 15th, 2009, 05:17 PM
Moderator
Default davea :
Post by davea on Nov 21, 2006, 11:10am
Late 80's/early 90's Ford F350's used a drivers drop D-60 and if you run spring over, the factory ford spring pads are in exactly the right place for the M trucks. only drawback is that the factory ford steering arms put the pass. side tie rod pretty close to the bottom of the spring pack. Has clearance in rest mode, but might rub during flex. Plus it has locking hubs and inner/outer wheel bearings vs. the Dodge's hubless, mono bearing setup.
Moderator
Default wi715 :
Post by wi715 on Nov 21, 2006, 11:13am
You could use Dana 60 out of a 86-91 F-350.
I'm using 1 out of '88. mounts used were Ford on the driver's side, Chevy on pass. side.
Got 2 for sale near Wi Dells WI.
John
Moderator
Default davea :
Post by davea on Nov 21, 2006, 11:16am
John, beat you to it. LOL
  #6
Moderator
Default wi715 :
Post by wi715 on Nov 21, 2006, 11:22am
Thats just because I type with 2 or 3 fingers
  #7
Moderator
Default davea :
Post by davea on Nov 21, 2006, 11:29am
I sent you a pm with a question. I wanna pick your brain since you have your steering ironed out.
  #8
Moderator
Default alosix :
Post by alosix on Nov 21, 2006, 11:38am
Was mostly looking for years of Dodge/Ford that might be useful.
Kinda like the idea of running the late model 241 that's coming with it.
Does the steering of the fords work ok if sprung under? Not looking to make this one any taller. Its going to most do parts hauling and light tow duty.
Thanks,
Jason
  #9
Moderator
Default davea :
Post by davea on Nov 21, 2006, 11:43am
John
I think top mount steering arms would work if you ran it spring under. You might have to blue-flame the stock arms off.
HTML code is On
robertcowan : FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE PseudoZone PseudoZone - Mod Tech Archive 24 December 15th, 2009 05:14 PM
Need front axle measurement scottsmyth Stock Tech 3 September 19th, 2009 03:10 PM
front axle lubrication stranman Stock Tech 20 November 13th, 2008 02:35 PM
front axle locker fwdstuck Modified Tech 3 May 20th, 2007 05:20 PM
m715 front axle heepofajeep Open Discussion Archives 16 May 24th, 2004 07:29 AM
