Old December 15th, 2009, 05:19 PM
Moderator
PseudoZone is a Soldier
Default squatch : new old truck??
new old truck??
Post by squatch on Nov 21, 2006, 9:48pm
newbies 1st post! lot's of questions. I'm looking at an m715 locally no major rust. bbc 396 fresh rebuild novak adapter instal, custom wheels(steel 16.5) 38" swampers,12 volt, power steering. Otherwise stock. I like it. Heres the deal. I'm looking for a truck to tow my 17' alum bass boat and haul firewood, and other basic chores. Is this realistic with gearing change(4.56?), radial swampers, turn signals, comfy seats, rollcage, heater defrost(no heater now), some sound deadening, and disc brake conversion. Will it drive ok at 70 mph on east coast highways(dummys in traffic!!). I haven't driven it yet! I also have '80 Dodge pw stepside"like lil red express". 383b, np435,208, d60 disc fr, d70 rr, 35"mt's. It has rust issues but drives like a dream. I'm not a body man and think m715 would be less work. ie:all mechanical. Pw could be parts doner.Tthanks in advance.
Moderator
Default tacomainoh :
Re: new old truck??
Post by tacomainoh on Nov 21, 2006, 11:33pm
The gearing is still not really high enough, unless you like revving yer engine. I'd choose something else...
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Re: new old truck??
Post by brute4c on Nov 22, 2006, 10:11am
With tires that are a true 38 inches tall and 4.56 axle gears, not counting any overdrive gearboxes, you would be turning 2420 RPM at 60 and 2820 RPM at 70 on the highway...if that helps...any tire taller than 38 inches and you need some lift...
Moderator
Re: new old truck??
Post by tacomainoh on Nov 22, 2006, 10:30am
Radial Swampers are still really squirmy and aren't that good in a braking situation in the rain either....
Elwenil's Avatar
Elwenil Elwenil is offline
Private 1st Class
Elwenil is a Soldier
Default elwenil :
Re: new old truck??
Post by elwenil on Nov 22, 2006, 10:53am
Not to mention the rarity and cost of a gear swap and there is no real solution for a disc brake conversion since it seems to cost more then the trucks themselves. The transfer case would have to be swapped out also for a lot of highway driving. A 715 is a good truck to have as a toy or a resto project but not a general work truck without a lot of mods. Michelin XLs or XZLs would be a better tire choice than anything from Interco.
I'd go with the Dodge. Better axles, better engine, and better parts availability. I'd toss the 208 in favor of a 205 though.
  #6
Old December 15th, 2009, 05:20 PM
Moderator
Re: new old truck??
Post by tacomainoh on Nov 22, 2006, 11:09am
Stepside=sh*tty tow rig.
XL's don't bring the stick to the rock MOOAHAHAH
208 has a better low, I'd keep it.
  #7
teking teking is offline
Private 1st Class
teking is a Soldier
Default teking :
Re: new old truck??
Post by teking on Nov 22, 2006, 11:15am
Here's a friggin work horse Dodge baby! My Dodge hates me.
  #8
Elwenil's Avatar
Private 1st Class
Default elwenil :
Re: new old truck??
Post by elwenil on Nov 22, 2006, 11:20am
Ok, Tac. You are probably just messing with me, but I'm curious as to why a step side isn't desirable for towing? It's not any worse than any other shortbed truck. Granted I do prefer a longbed for towing but he's only towing a boat.
And yeah, XLs are hard as a rock themselves, lol.
  #9
Moderator
Re: new old truck??
Post by tacomainoh on Nov 22, 2006, 11:53am
You answered your own question! I would never tow with a shortbed.
  #10
Moderator
Default squatch :
Re: new old truck??
Post by squatch on Nov 22, 2006, 6:55pm
Thanks folks. Looks like I started some fun. M715 i thought the offset tc might be noisy at best. As for the stepaside. it has 4" skyjacker soft ride all steering correction stuff and factory swaybars with drop brackets. it spins about 2600rpm @ 60 with 35x12:50s. the 208 is a dodge version not chevy no slip yoke. it's in driveshaft where it belongs. 208 has over 300k never been opened and i have a spare. It tows the boat fine(only about 2000lbs. maybe i'll do both. l
HTML code is On
finally turned fire truck back into an army truck stranman Open Discussion 11 July 8th, 2008 04:57 PM
Pic of truck one. ronzello Modified Tech 4 February 26th, 2007 03:19 PM
