  #11
Old December 15th, 2009, 05:21 PM
Moderator
PseudoZone is a Soldier
Default calpyro :
Re: Painless wiring
Post by calpyro on Nov 22, 2006, 2:18am
I got the 21 circuit EZ Wiring kit. It is long enough for a M715. I also got the headlight and ignition switches. As far as I can tell, it was the cheapest available. it went in without a hitch. Total cost about $210
  #12
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default compexp :
Re: Painless wiring
Post by compexp on Nov 22, 2006, 4:09pm
Quote:
Compexp-Just checkin-that kit you got from summit is a Painless kit then?? I see it says standard length-Going by what you said about mounting it under the hood it if you did it over----would it have then been too short?? I see they do have a kit listed as universal truck long....
I see a ton of the cj kits and bronco ones on ebay but the truck ones seem rare as hens teeth
It would be fine under the hood - because I mounted it under the dash, i then had a 3' run to just get out of the cab into the engine compartment - that 3' would give me enough for the passenger taillights.
  #13
Moderator
Default tomahawk715 :
Re: Painless wiring
Post by tomahawk715 on Nov 22, 2006, 10:25pm
Ok gottcha-I see what you mean-Like I said just want to do this with no splicing.
  #14
Old December 15th, 2009, 05:22 PM
Moderator
Default hummer103 :
Re: Painless wiring
Post by hummer103 on Nov 24, 2006, 2:24am
Im running a 12 cirrcuit Painless Harness I bought a few years ago, way too many wires. I used like a third of them, Harness cost me like 300-something I think. Real pain trying to hook up some of the stock interior switches and things, but I decided to to that.
HTML code is On
Need wiring help ldj1002 Open Discussion 3 September 17th, 2009 08:36 PM
Turn signal switch/painless harness Craig Merrill Modified Tech 6 March 9th, 2009 08:41 AM
painless wiring harness? spgirard30 Modified Tech 9 February 8th, 2009 02:31 PM
Aftermarket Wiring Harness - Painless Type Fastfrankie Open Discussion 6 November 19th, 2008 01:50 PM
Wiring archjr Open Discussion 2 January 28th, 2008 03:42 PM
