  #51
Old February 9th, 2016, 11:20 AM
brycer1968's Avatar
brycer1968 brycer1968 is offline
Private 1st Class
brycer1968 is a Soldier
Test . . . And fail
  #52
Old February 9th, 2016, 11:33 AM
brycer1968's Avatar
Private 1st Class
Default Second try
Okay, so looks like I'm figuring out that you should not try to copy pics from photobucket on handheld or I-pad devices. So this is just one of the pics in the album. I assume that all can be viewed by clicking on this one?
Bryce
  #53
Old February 9th, 2016, 11:39 AM
brycer1968's Avatar
Private 1st Class
  #54
Old February 9th, 2016, 11:40 AM
brycer1968's Avatar
Private 1st Class
  #55
Old August 30th, 2016, 06:53 PM
fishtail's Avatar
fishtail fishtail is offline
Sergeant
fishtail is a Soldier
I am repairing another set of seats. This time I am also working on the seat bottoms/spring pacs.
Although the pic isn't the best, here are NOS bases only in the center of the pic. The come with the riveted mounting brackets. I got them from VPW.
[IMG][/IMG]
Here is a pic of a whole crate of the bottoms at VPW.
[IMG][/IMG]
OK, here's a pic of the bottoms.
[IMG][/IMG]
Here is a pic of the old seat bottoms, note the rot where the support rod staples down. This is the only place they were bad.
[IMG][/IMG]
I removed the spring pacs from my old seats. The springs were in excellent shape and not rusty. Just pull out the staples with a side cutters. Takes about 15 minutes to get all the staples out of a whole seat.
Power wash the seat spring pacs. Make sure none of the springs are not loose from the clamps, and any of the small springs are not broken or poking upward.
Place them on the new seat bottom. Look at the spacing from your other seat to make sure you got them in the right spot. NOTE: the spring pacs should be flush with the back of the board, and overhang the front by 2 inches or so.
I didn't save the package for the staples. They measure .150 ID by .625 long. I got them from a regular hardware store. They come in long packs like desk staples do. Just cut them apart with a utility knife. Hold them in place with a needle nose pliers and tap them in place with a punch. It took a good half hour to staple the spring pacs down.
Note: Use three staples per coil, and three staples for each rod end.
[IMG][/IMG]
Staple the two rods last, as you can use them to straighten out the spring pacs a little.
Here is the spring pacs stapled to the NOS board.
[IMG][/IMG]
Here are two now painted OD and ready to receive the new seat coverings.
[IMG][/IMG]
Scott
Stock seat covers da mule Stock Tech 2 July 7th, 2009 07:34 AM
need seat backs johnny rezny Stock Tech 3 February 9th, 2008 02:36 PM
seat help willy Open Discussion 10 January 13th, 2008 08:28 PM
Headrest modification on stock seat Calpyro Modified Tech 4 August 27th, 2007 09:40 PM
Stock specs for stock axle, wheel, brake drums & tires brute4c Stock Tech Archives 0 May 31st, 2007 06:46 AM
