Old February 18th, 2010, 10:02 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Default Solid State Flasher Box Test
Here is the solid state blinker box test:
Pin "A" to a light bulb which is grounded (I use a test light)
Pin "B" to a 24V DC source (12V will work)
Pin "C" to ground
When "B" is connected, the light should blink about 80 times per minute.
Old February 22nd, 2010, 10:06 AM
amphi's Avatar
amphi amphi is offline
Corporal
amphi is a Soldier
Default Additional Tests:
Another method for testing the solid-state flasher module:
Method for testing the turn-signal switch:
Turn-signal switch diagram:
Old January 16th, 2011, 10:15 PM
militarypotts's Avatar
militarypotts militarypotts is offline
Sergeant
militarypotts is a Soldier
My turn signals seem to work when they want to. I have a new flasher unit, but haven't installed it yet. Wondering if it could be the ground. One day the turn signals and emergency flashers will work, the next day not. Sometimes they work or won't work all in the same day? Any ideas?
Old January 17th, 2011, 06:25 AM
Barrman's Avatar
Chief 9-flats
You are on the right track. Check your grounds and all the connections. I have never had a solid state military blinker box "kind of" work. They either work or they don't.
Now, I have had a few that light up either the blinker at the fenders or blinker indicator inside and not flash. Others will just not work in any way shape or form. Either fault, is permanent and constant.
I have found that most people have no clue how to check these things and will sell or give away good ones as "bad" at shows and gatherings if you ask them for faulty ones. For some reason we just don't throw the bad ones away.
I have a bag of about 30 now. 5 have tested as good. Not bad when all were free over a few years of asking for bad ones everytime I go near military parts.
Old January 17th, 2011, 06:31 AM
Sergeant
Thanks Barrman, I do occasionally have the problem of the blinker light on the steering column coming on and staying on. Sometimes I can blink it manually by moving the lever up and down. Very weird.
  #6
Old January 17th, 2011, 09:31 AM
Barrman's Avatar
Chief 9-flats
That is probably your blinker arm or 3 lever switch then. One of mine just goes dead on the blinker circuit until I jiggle the 3 lever. It happens with no pattern or reason too.
  #7
Old January 17th, 2011, 10:24 AM
Sergeant
Thanks, I'll start with the ground. I've taken the turn signal box on the steering column apart and it looks brand new. My guess is maybe the ground on the firewall of the truck. I hate electrical problems, but I guess it's a fact of life when you own older vehicles.
  #8
Old August 1st, 2011, 09:41 PM
MJCougler's Avatar
MJCougler MJCougler is offline
Private 1st Class
MJCougler is a Soldier
Default Turn signal question
Barrman,
I have a related turn signal question.
Whenever I drive, I remember to turn on the upper lamp switch one click to the right so the turn signals and the brake lights work (but not the headlights). Often I forget to turn this switch off at the end of the ride. Will leaving the switch on hurt the circuit, drain the battery, or anything bad? Will the fuse blow to "save the circuit" if there is a problem?
Thanks in advance,
Mike Cougler, MSgt, USAF Retired, '72-93
'67 M725, VIN 10030, Delivery: 7/67
Rochester, NY
  #9
Old August 2nd, 2011, 06:58 AM
Barrman's Avatar
Chief 9-flats
When you have the old style switch with actual levers, leave it on the first click to the right all you want. Unless you leave the blinkers on or have a stuck brake light, nothing bad will happen.
However, if you have a newer push button switch. You have to push the buttons and make it turn off every night or the battery will go dead.
Flasher unit berkahna Stock Tech 2 December 7th, 2009 09:22 AM
Solid Plate Steel Wheels fisherman Open Discussion 12 April 10th, 2007 09:46 PM
Solid bed mounting boghog Modified Tech 6 December 31st, 2006 09:02 AM
Solid motor mounts? Brian Sisson Open Discussion Archives 15 March 31st, 2004 07:12 AM
