  #31
Old August 28th, 2016, 10:11 AM
Nailhead's Avatar
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
Quote:
Originally Posted by AHood View Post
I thought of it. im a machinist and I was working at a shop where i had free reign over the machines there in my off time so i was doing this for free for my self. its possible i could produce just the cam and pins but i would need a shop that could do 4 axis milling for me to make any more of them. I still have the cad model of the cam i made. the pins were specific because i remachined and tapped the hand hub for them. they were larger overall with larger threads into the hand hub and all.
I plan to buy a set of Selectros, and would be very interested in replacing the plastic parts with the metal ones you machined, if at all possible.
That's no place for plastic, IMHO.
  #32
Old August 28th, 2016, 05:53 PM
AHood AHood is offline
AHood is a Soldier
Heres the socket tool.
  #33
Old October 29th, 2016, 08:15 AM
Nailhead's Avatar
Corporal
Can someone detail the hub installation process for me?
I received my new Selectros yesterday and the instruction sheet included is written as though there was an exploded view of the hub with the components numbered. There isn't, so I have no idea what the hell they mean: "CAUTION!!! If the screws in position B should be removed...." On and on, not worth paper they're printed on.
The last time I messed around with Selectro hubs was the mid-'80's when a Landcruiser mechanic showed me how to service/disassemble them, and I've forgotten what he said.
  #34
Old October 29th, 2016, 11:25 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
I followed the instructions when I installed the first side... second side I asked myself WHY?! On that one I just pulled the axle plate off and bolted the assembled hub in place.
I used some Ultra Black instead of a gasket.
  #35
Old October 29th, 2016, 04:31 PM
Nailhead's Avatar
Corporal
Thanks Von. I'll do that. The instructions included with my hubs are unusable, so why not?
  #36
Old April 29th, 2018, 03:43 PM
Kaiserman Kaiserman is offline
Kaiserman is a Soldier
FYI the early Selectros had metal cams. They are swappable from the small bolt pattern hubs to the large. So if you can score a pair off a CJ or similar cheap you can run the whole dial assembly on your M715 hubs.
1963 J300/1971 J2000/1983 J10
  #37
Old April 29th, 2018, 03:57 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
That is great tech...thanks for posting it!!!
  #38
Old October 30th, 2019, 06:29 PM
nolfy's Avatar
nolfy nolfy is offline
nolfy is a Soldier
OK maybe I missed it somewhere. Why replace the studs with bolts anyway? I never saw a stud come loose.
  #39
Old November 1st, 2019, 07:21 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Quote:
One reason, the studs sticking up around the selector makes it a pain. Especially the 4 long studs. I used some grade 5 allen head bolts I had on hand, kept meaning to switch to grade 8 but never got around to it...
Woop!! I got those ring and pinion gears installed in my truck a week or two ago.
YUGE difference... The 390, 4 speed and the 4.56 gears get along very nicely.
  #40
Old July 16th, 2020, 10:48 AM
dycott78 dycott78 is offline
Civilian
dycott78 is a Soldier
Excellent, they remind me of the designs I saw in my favorite web forum SEO, it has excellent information
